Moonroof leaks?
Posted: Sun Jan 19, 2003 11:17 am
by justinawd
I took my vibe a touch free automated carwash today and I noticed that water was leaking through the moonroof when the pressurized water stream hits that area. Has anyone else noticed this? Is this expected or should I bring it to the dealership?thanks.justinawd2003 Pontiac Vibe AWD. Salsa Red. Moon and Tunes package.
Re: Moonroof leaks? (justinawd)
Posted: Sun Jan 19, 2003 11:46 am
by NovaResource
Yes, there was a technical service bulletin about this. The drain tube can sometimes fall off causing a leak. Take it back to the dealer.
Re: Moonroof leaks? (NovaResource)
Posted: Sun Jan 19, 2003 12:15 pm
by NSimkins
quote:Yes, there was a technical service bulletin about this. The drain tube can sometimes fall off causing a leak. Take it back to the dealer.Here is the PDF of the document (download Acrobat here):
http://www.nhtsa.dot.gov/TSBScans/sb629757.pdfQuoted from:
http://forums.genvibe.com/zerothread?id=1545
Posted: Wed Jan 22, 2003 8:30 am
by ngilbert
Coud be also a faulty moonroof gasket/surround. The dealership replaced it and it cured my leak problem. However, since the're was a TSB on it they may have done that as well, but it was not written on the work order.
