Taking out stock 6-changer. Anything i should be warned before hand?
Posted: Tue May 09, 2006 5:43 am
by josholiver1
I just got another 03' vibe and i want to take out the 6disk changer. Is there anything i need to be warned before doing so?The solid one pannel is all that i need to remove?Is there any tool i need to do this?
Re: Taking out stock 6-changer. Anything i should be warned before hand? (josholiver1)
Posted: Tue May 09, 2006 6:59 am
by GMJAP
Quote, originally posted by josholiver1 »I just got another 03' vibe and i want to take out the 6disk changer. Is there anything i need to be warned before doing so?The solid one pannel is all that i need to remove?Is there any tool i need to do this?Nothing special. The only slightly unusual tool you'll need is a hex driver or socket wrench for the radio hex screws.Just pry out the silver trim from the bottom with your fingers (right above the HVAC dials.) You'll then need to remove 4 connectors to the switches on the trim- make sure you press the tab on the connector while removing it. You can remove the cable too, but it'd probably be easier to pull some cable out of the dash (gently) and let the trim dangle from it.There's four hex screws on the radio brackets that hold it in, in roughly each of the 4 corners. Remove them, gently pull the radio out, remove the antenna cable and the connector(s) from the back.Install in reverse order!
Posted: Tue May 09, 2006 8:35 am
by josholiver1
What cables? I thought that the trim piece just pops off? there are cables hooked up to the trim piece?
Re: (josholiver1)
Posted: Tue May 09, 2006 9:09 am
by ColonelPanic
The cable attaches to to A/C / recirculate switch assembly and goes down to the climate control assembly.
Posted: Wed May 10, 2006 9:56 am
by josholiver1
Ok so i just got it home and took the face plate off. Now i see what you guys are takn about! i thought everything was fassened to the dash and the silver faceplate just moved freely!Thanx you guys!
Posted: Wed May 10, 2006 10:32 am
Quote, originally posted by josholiver1 »I just got another 03' vibe ... (removed)?Is this a second one, or one to replace the other one?(what this explained in a thread I missed?)
Posted: Fri May 12, 2006 8:35 am
by josholiver1
Sorry Jotmon, Yes after all the hasle i ended up selling my previous 03' and then a realistate agent in troy, MI was selling his 03 and i purchased it for 12,700. It has 33,000 on it. I will post pics soon! sorry for the confusion..
Posted: Fri May 12, 2006 9:13 am
by josholiver1
The owner bought his truck up here and he decided to buy a new car so they droped the new one off in troy and drove the vibe up here. So it wasnt a very long drive 4 me! Lol
Re: (josholiver1)
Posted: Fri May 12, 2006 9:18 am
by josholiver1
Here is some pics
Re: (josholiver1)
Posted: Fri May 12, 2006 9:22 am
by josholiver1
Another...
Re: (josholiver1)
Posted: Tue Aug 22, 2006 9:39 pm
by new05vibeowner
Do you still have the 6-CD? If you do, I'm interested in buying it.
