vibrating Vibe
Posted: Sun May 07, 2006 3:53 am
by Digger
For those of you who have developed a vibrating vibe when placed in gear, try this tip from the car care section of PM. Loosen all of the motor mount bolts at once then start the car and put it in drive. Turn off the engine and retirten all the bolts. According to them the vibration is the result of a crooked motor.
Re: vibrating Vibe (Digger)
Posted: Sun May 07, 2006 7:13 am
by JohnC
Great tip. I use to have to do this to my Neon after a couple hard launches.
Re: vibrating Vibe (JohnC)
Posted: Mon May 15, 2006 2:52 pm
by lombaki
We've had our vibe since June 2005 (love it to death) but we do have a vibration around 3,000 RPM. Could tis be a crooked mount? And if so can the techs at Pontiac do this under warranty? I'm no one to start loosening things on my engine, it would probably fall out. -Fusion Orange, Monotone, PWR PKG, Moon and TunesThanks in advance! Greg
Posted: Tue May 16, 2006 3:56 am
by northvibe
lombaki - i think that might be something else...not sure ive never had my engine vibrate. but that could be a warped rotor. I think it will depened on any noises you hear and where you feel the vibrating
Posted: Tue May 16, 2006 6:24 am
by lombaki
We don't so much feel the vibration but we definitely hear it at 3000 RPM. It's certainly coming from the engine compartment and can't currently afford to shell out the $xx per hour for a tech to work on it. We were hoping to find a common thread with other owners. Perhaps not tho. thanks!
Posted: Tue May 16, 2006 9:33 am
by Digger
My brother had an explorer do that. It turned out to be a bent cam shaft. Hope that is not it. Does it do it in all gears or just crusing speed.
Posted: Mon May 22, 2006 6:48 am
by lombaki
It's during acceleration once we get to 3k rpm and above. And now my wife claims her MPG has decreased noticibly. I'm ready to take it in unless someone has a brilliant idea...?
Re: (lombaki)
Posted: Wed May 24, 2006 6:00 pm
by Hollow
Inner CV joint (I hope u know whar I mean)
