biq question.. plz help me
Posted: Sat May 06, 2006 7:05 am
by P-Fernandez
so i got the reflector overlys.. and i got some q'sINSTALLED!!!! ook for my tread " Reflector overlays & arrowhead oeray installed"- Do you have to take the headlight assembly off?- If you did it, did you use water and soap.. like it says on install sheet?
Posted: Sat May 06, 2006 8:25 am
by northvibe
i just cleaned the spots with a wet wipe aka rubbing alcohol in a wipe . soap and water will do too, wait till it dries. Where did you order them from? i think vinyl like that you spary a little soapy water on the back of the vinyl and then lay on the head light and smooth out with like a credit card. you should not have to take off the headlight.
Re: biq question.. plz help me (P-Fernandez)
Posted: Sat May 06, 2006 10:39 am
by scherry2
no removal needed. use soap and water and I used a blowdryer (not close), your working with a compound curve so take your time. they go on easy just follow the instructions.
Posted: Sat May 06, 2006 12:06 pm
by P-Fernandez
ok wel thanks..i did it about 1 hour ago. i cleaned it, sprayed soap & water, put it on there stretch it out little by little, and the used a blowdryer. 1st one--- not perfect2nd one--- good
Re: (P-Fernandez)
Posted: Sat May 06, 2006 1:45 pm
by NascarXprt
try and get some pics of final product.
Posted: Sat May 06, 2006 2:35 pm
by P-Fernandez
i jst posted a tread about it and pics.. Relector overlays & arrowhead overlay "instaled:
Re: (P-Fernandez)
Posted: Sat May 06, 2006 2:43 pm
by NascarXprt
yea i kind of saw that after i posted this looks great by the way
