Noise when going from reverse to 1st
Posted: Thu May 04, 2006 4:09 am
by shane_c
It seems that when I put the car in reverse and back up, come to a complete stop, put it in 1st and go to pull away that I can hear a noise coming from under the car. Sounds kind of like a hollow clunk. Anyone else get this?
Re: Noise when going from reverse to 1st (shane_c)
Posted: Thu May 04, 2006 4:11 am
by BlueCrush
If it does it only when you back up for the first time after starting the car, that's the ABS system initializing.
Re: Noise when going from reverse to 1st (BlueCrush)
Posted: Thu May 04, 2006 6:51 am
by shane_c
I've never heard of this on a car before but that would explain it.
Posted: Thu May 04, 2006 7:06 am
by BlueCrush
Try backing up and going forward a few times to see if it keeps doing it each time after your initial start/reverse/1st run. That will tell you if it is the ABS or not. Let us know your findings after doing this.
Posted: Mon Jul 31, 2006 4:05 am
by Vangrest
Glad I found this post!! my 2005 Vibe was making the same strange clunking noise. I tested it out and found out it was only after going in reverse and then moving forward between first and second gear shifting. I notified the dealer and they checked out the brakes and did some minor adjustments and lubrication which seems to have fixed the issue!Thanks again folks.
