Tach Help
Posted: Wed May 03, 2006 10:07 pm
by MarathonVibe
How do you set up a Tach ?
Posted: Wed May 03, 2006 10:17 pm
by Jahntassa
I guess you mean a second tachometer? Did you buy one yet, and if so, did you look at the instructions?
Posted: Thu May 04, 2006 11:25 am
by MarathonVibe
well i got it used from a friend and the only thing i really need help with is the green wire. I know on my old car it went to the coil.
Re: (MarathonVibe)
Posted: Thu May 04, 2006 10:56 pm
by djb383
The green wire goes to the negative side of the coil, usually.
Posted: Fri May 05, 2006 12:36 am
by Jahntassa
According to the sheet I used to put in my remote start, here's the colors:Coils:- Red/Blue- Yellow/Green- Gray- WhiteFor the remote start, I used the fuel injector wire, which is the wire at any fuel injector that is NOT black/white
Posted: Fri May 05, 2006 4:55 am
by MarathonVibe
Thanks i will give that a try
