Friday, I've just changed my 2 front speaker to new Boston Acoustics S65. These are 2 way speakers and boy is there a world af differnce between them and the OEM ones.I now have all of of the Highs I need without losing my Bass.The only thing is that it's a bit of work to put them in but the sound is worth the work.if you're thinking to do the change, go for it, it worth every penny.
'05 Moonstone, 5 Spd sunroof, power pkg, 16'' mags
It took me about 2 hours, but for the next one it will be a lot quiker. I now have a template and will probably do a fiberglass frame.No problem for the help and let me know if you need frames to hold them and if you're changing all 4 or only 2.thanks
Congrats on your install.I havent installed speakers in the door in the past.Dont the speakers come with a template?Did you have to fabricate a spacer ?Did you have to force anything or cut out any parts of the door?Do the tweeters point upward for better distribution of highs?Thanks
No they don't come with a template, at least not these, and yes I had to do a spacer for these, 1/2" thick is just right. and no the tweeter doesn't point up toward you.thanks
