installing GPS tomorrow, reverse indicator location?
Posted: Sat Apr 22, 2006 11:37 am
by jeffgtx
installing a kenwood GPS tomorrow and need a reverse indictor so the gps knows when i am going backwards, should i decide to go backwards whilst being navigated.anybody know an easy place to get that in the inside or do i need to go to the reverse lights in teh back?
Posted: Sat Apr 22, 2006 12:14 pm
by Jahntassa
I know where it is if you had the Nav system Not sure where you can get it other than the reverse lights, but then I don't have a book on the car.
Re: (Jahntassa)
Posted: Sat Apr 22, 2006 1:47 pm
by mcgusto82
i agree with jahntassa. the reverse light is a good place to start. there should be a 2 wires that come out of the tranny near the shifter cables. (i think) you could trace them into the fire wall.
Re: (mcgusto82)
Posted: Thu Apr 27, 2006 7:47 am
by jeffgtx
the answer is right behind the glove compartment. to the right of the ECU is a white connector with a red/blk wire coming out (pin 4 i believe) which goes to 11V when reverse is engaged.
