Intake ?????'s
Posted: Sat Apr 22, 2006 1:55 am
by P-Fernandez
ok so im thinking about buying an intake from cosmo ( 06 Base) , im eaning towards the SR bc of an easier install.. i live in south ga , but wil be soon( 1 1/2 months) moing to ATL , would an SR be ok for me?( mostly highway driving ) anyone had problems while installing, time to install? tools?
Re: Intake ?????'s (P-Fernandez)
Posted: Sat Apr 22, 2006 2:01 am
by Mrizzle05
There are a lot of other threads like this about if a SR is ok for people out in that area or rainy areas.SR= good sound, HP increase.... easy install.CAI= better cooler airflow, HP increase, more difficult.I have a CAI on my base 05. it was a pain and i need to modify it a lil, ie: buy radiator hose for intake inlet to engine inlet. and i had to chop off about 3" from the end of the intake to make fit above the fog light.SR youd probably have to still get a longer hose to fit the inlets. but just remove the stock box and slap that bad boy in there. put the MAF sensor back in and run it for a lil bit to let the ecu recognize the more airflow, then enjoy.Everyone else might throw in there $0.02 too!
Posted: Sat Apr 22, 2006 2:43 am
by AKLGT
Quote, originally posted by P-Fernandez »ok so im thinking about buying an intake from cosmo ( 06 Base) , im eaning towards the SR bc of an easier install.. i live in south ga , but wil be soon( 1 1/2 months) moing to ATL , would an SR be ok for me?( mostly highway driving ) anyone had problems while installing, time to install? tools?i view the sr as just for sound a tad bit of extra oomph. if you're gonna do it, do it right and go with the cai. it will make a big difference on the base, plus in that kinda heat, you'd just be pushing hotter air into your engine with a SR. go CAI. but that's just mho. lots of threads on this if you want to search CAI vs SR
Posted: Sat Apr 22, 2006 11:11 am
by Digger
I went for the SR and would do it again if had to.
