I snapped a lug stud!
Posted: Fri Apr 14, 2006 8:17 am
by LavaMyVibe
So it has finally happened. I wasn't paying attention to the setting on the torque wrench (put on the summer wheels for my Focus a week ago which requires 94 ft/lbs) and I thightened the lug nuts. One lug nut just kept turning and turning... grrr... So now I have to replace the stud. Does anyone have instructions on how this is done? Does the rotor have to be removed first? HELP!
Re: I snapped a lug stud! (LavaMyVibe)
Posted: Fri Apr 14, 2006 10:07 am
by scherry2
only 94 ft/lbs. *shakes head* thats nuts!
Re: I snapped a lug stud! (scherry2)
Posted: Fri Apr 14, 2006 10:42 am
by Mavrik
yet another one that snapped off around 100lbs... I'm not understanding how they are overtorqued.
Re: I snapped a lug stud! (Mavrik)
Posted: Fri Apr 14, 2006 10:50 am
by LavaMyVibe
Quote, originally posted by Mavrik »yet another one that snapped off around 100lbs... I'm not understanding how they are overtorqued.Am I missing something? Is 100lbs some kind of a magic mark? Is this a common occurance? Or do we just get fed too much mad cow in Canada ?
Posted: Fri Apr 14, 2006 11:05 am
by Raven
Yes snapping at 100 lbs seems to be very common on the Vibe, kind of sensitive when 76 lbs is recommended. I've heard of it many times.
Posted: Fri Apr 14, 2006 11:34 am
by JustinVGT
I guess I'm lucky my studs didn't snap when the shop torqued mine to over 150 lb/ft. It broke the meter on my torque wrench which had a max of 150 when I was trying to remove the lug nuts.
Posted: Sat Apr 15, 2006 11:03 am
by LavaMyVibe
So after running around saturday trying to get a shop to fix the broken lug stud, I gave in and went to my local Toyota dealer (Pontiac dealer was closed for Easter weekend ) and picked up 2 studs in case I mess one up. Grand total of C$12. Popped off the front wheel, removed the caliper, hammered out the broken bolt using a socket wrench extension. Then I had some fun with putting in the new bolt. It took a bit of convincing with a hammer but finally managed to get the new stud into place. Used 4 keystone washers and one of the lugs to pull the stud through. Got all the installation details from this Focus site->http://www.focushacks.com/index.php?modid=44 ...except of course step #10. Torque to 76LBS! 76LBS!
Posted: Sat Apr 15, 2006 11:05 am
by Raven
Good job Nothing like the satisfaction of DIY.
Posted: Thu Apr 19, 2007 11:40 am
by matteldridge
thanks i just snaped a stud and your instructions were a great help
Posted: Thu Apr 19, 2007 11:49 am
by nygiantzz1
Don't feel bad, 94lbs is a little too much, but not entirely the cause of the problem. I snapped 4 of them over a 5 year period on my Ford Explorer. cheap lug studs.
Re: (JustinVGT)
Posted: Thu Apr 19, 2007 8:38 pm
by Mario
Quote, originally posted by JustinVGT »I guess I'm lucky my studs didn't snap when the shop torqued mine to over 150 lb/ft. It broke the meter on my torque wrench which had a max of 150 when I was trying to remove the lug nuts. Why would you use a torque wrench to REMOVE anything?
Re: (Mario)
Posted: Thu Apr 19, 2007 8:46 pm
by Vibr8tr
The good news, even though they have a tendancy to snap... it's a cheap fix. I mean, at least you don't have to buy anyrthing major, just a large bolt, lol.Good DIY explination, now I know how easy it s.
Posted: Mon May 28, 2007 12:52 am
by Sublimewind
One of the MAIN contributing factors in stretching or snapping a lug stud is, improper torque wrench setting (if your using one, which is VERY good for your brake rotors) NOT using a TW, or LUBING the threads with anti-seize or some other lubricant.. I made up a post regarding this in the Handling, Suspension, & Brakes area, it's well worth the read....
