Removing catalytic converter
Posted: Wed Apr 12, 2006 10:21 pm
by bigcar86
I own a base 05 matrix with these mods : borla exhaust, aem cai, aem pulley, eibach springs. I want to straight pipe it and remove all catalytic converters to have the loudest sound possible. Can anyone help me out as to how i would go about doing this?..pictures would be great
Re: Removing catalytic converter (bigcar86)
Posted: Wed Apr 12, 2006 11:49 pm
You'll need a custom built pipe that will replace the existing one. which looks like thisand you'll also need some sort of thing that will trick the computer into thinking there is a functional second O2 sensor, or else you'll have a permanent CEL.Glad you live far away from me.
Posted: Thu Apr 13, 2006 12:17 am
by damronjr
You said Borla exhaust but I don't know if it's axelback or what, but I cut my resonator out and have a cat-back straight 2.5" pipe with a Flowmaster muffler, but it sounds really tinny now, and I would think if you remove the cats it's going to get even worse.
Re: Removing catalytic converter (damronjr)
Posted: Thu Apr 13, 2006 2:56 am
by Mavrik
You do know ontario cops... and definatly toronto ones will pull you over for noise and the smell of unburnt gas coming from your exhaust. They will perform and exhaust output carbon test and write you up a nice thick fine. Plus you will fail your emissions test.Just a heads up.
Posted: Thu Apr 13, 2006 3:01 am
by Psychobroker
Quote, originally posted by damronjr »You said Borla exhaust but I don't know if it's axelback or what, but I cut my resonator out and have a cat-back straight 2.5" pipe with a Flowmaster muffler, but it sounds really tinny now, and I would think if you remove the cats it's going to get even worse.Borla doesn't make a cat-back for the Matrix/Vibe, so it has to be an axel-back.
Re: Removing catalytic converter (Psychobroker)
Posted: Thu Apr 13, 2006 3:37 am
by damronjr
Quote, originally posted by Psychobroker »Borla doesn't make a cat-back for the Matrix/Vibe, so it has to be an axel-back.Ok, well I figured maybe he got a custom res-back like I did or maybe even a custom cat-back with just straight pipe, but you're probably right, it's probably just an axle-back. Either way, since I removed my resonator a few days back I now have a strong tinny sound in the exhaust that I really didn't want. When I can afford it and if they make it for the 1zz, I would like to get a Blitz exhaust system. I heard it on a XRS and it was awesome!
Posted: Thu Apr 13, 2006 4:30 am
by bigcar86
my borla is actually a cat back.....wat is a resonator???.....wat if i put a high flow catalytic converter???
Posted: Thu Apr 13, 2006 5:13 am
by ToolGuy
Cut out and straight pipe the resonator and get high flow cats. IMO...
Posted: Thu Apr 13, 2006 7:50 am
by Psychobroker
Quote, originally posted by bigcar86 »my borla is actually a cat back.....wat is a resonator???.....wat if i put a high flow catalytic converter???Is it custom then, because they don't make an out-of-the box cat-back exhaust. Sure, they CALL it a cat-back, but unless it replaces the resonator, it's still an axelback. A resonoator is the big tube/bulge after the two cats, as illustrated so nicely by joatmon:
