Were to run the power cord from battery from exterior amp?
Posted: Tue Mar 28, 2006 7:57 am
by josholiver1
Were do you run the power cord through from the amp to get to the battery? Firewall? Dash? Behind Radio? Any pics would be great!!!!!!!!!!!!!!!!!!!!!
Re: Were to run the power cord from battery from exterior amp? (josholiver1)
Posted: Tue Mar 28, 2006 8:21 am
by damronjr
Me, firewall behind the glove box. There is a rubber grommit coming through the firewall already there with some other crap coming through. It is an oversized grommit too, so making a hole and using it works very well.
Posted: Tue Mar 28, 2006 12:47 pm
by 4azdmunky
I went right through the grommit behind the engine on the right. It runs under the dash around the glovebox to under the front seat.
Posted: Tue Mar 28, 2006 11:29 pm
by Jahntassa
I went through with the main wiring harness right above the gas pedal.
Posted: Wed Mar 29, 2006 6:04 am
by josholiver1
thanx,Any pics on were the glove box firewall is?And were did you run the speaker wire from the back of the stereo to the amp? Im just confused at were these cords get from the fire wall to the back of the head unit? Is there a hole close to the floor were the wires can be fead up to the head unit?The reason is...I am debating on wether getting the monsoon system in my next vibe or putting new head unit in and a Bazzoka amp and tube in...the way i look at it is that the cost will be almost the same and the Bazzoka tube will sound SO much betta!Monsoon- around 100 bucksAUX input from factory- around 400 bucks=500 bucksHead unit-120 bucksBazzoka Amp and Tube-120 bucksAmp wire and speaker wire-60 bucks=300 bucks200 dollars less and a better system
Re: (josholiver1)
Posted: Wed Mar 29, 2006 6:21 am
by Mrizzle05
Uder the shifter console... theres a nice amount of space to run the RCA's and remote wire... i just did that with my pioneer... gotta run the power and ground tonight too... I was gonna look on the driver side for a spot to run the cords! Well I guess were still waiting for a pic then
Posted: Wed Mar 29, 2006 6:32 am
by josholiver1
If u could get a pic that would be great. So theres an actuall "hole" or do u pull the plastic away?And when you take the stereo out is it easy to thread the wire from the floor to the head unit?ANd is the firewall under the glove box or do you have to open it up?
Re: (josholiver1)
Posted: Wed Mar 29, 2006 7:50 am
by Mrizzle05
Ill post up when i can... hopefully tonight! as far as the hole for the wires near the dash... i look at that tonight. I wanna run it on the other side but ill look and post pics tonight for sure.
Posted: Wed Mar 29, 2006 8:27 am
by josholiver1
great thanx
Posted: Wed Mar 29, 2006 9:23 pm
by JustinVGT
Like some others mentioned, I also used the grommet that is right above the pedals. I used a screw driver to puncture a hole for the wire to feed through. This gives the power lead a close, direct connection to the battery.
