Noise in the engine.
Posted: Mon Mar 27, 2006 11:12 pm
by dallarosaj
I replaced my stock header for a DC Sport one and now I have a sweeking noise where the header bolts into the cat, has anyone ran into this problem if so how did you stop the noise. I do not know if its the bolts or the gasket. Please let me know.
Re: Noise in the engine. (dallarosaj)
Posted: Tue Mar 28, 2006 12:45 am
by BlueCrush
Have you tried re-tightening the bolts?
Re: Noise in the engine. (BlueCrush)
Posted: Tue Mar 28, 2006 1:31 am
by Psychobroker
Quote, originally posted by BlueCrush »Have you tried re-tightening the bolts?That would be a good idea. Also, make sure they're torqued to spec.
Posted: Tue Mar 28, 2006 3:51 am
by Dezz1
Did the headers come with a gasket for the CC, and if so is it positioned correctly?
Posted: Tue Mar 28, 2006 8:11 am
by Lancer
It could also be that the spring bolts haven't settled yet. But yeah, tighten them a little more and give it a good shake to help them settle in place.
Re: Noise in the engine. (Lancer)
Posted: Wed Mar 29, 2006 4:38 am
by dallarosaj
Everthing is tight and lined up how it should be the sweeking just wont go away.
Posted: Wed Mar 29, 2006 4:39 am
by dallarosaj
Everthing is tight and lined up how it should be the sweeking just wont go away. What do you mean by settle?
Posted: Wed Mar 29, 2006 5:05 am
by northvibe
did you grease the bolts? and lube the gasket?
Re: (northvibe)
Posted: Wed Mar 29, 2006 7:38 am
by dallarosaj
Lub the gasket? no I did not what type of lub should I use for it without it burning off the gasket? as for the bolts/springs should it need lub?
Posted: Wed Mar 29, 2006 11:13 am
by northvibe
hmmm now to think of it..it might have to be special stuff because that header is going to get HOT. check a auto store and see what they say.
