Airbags
Posted: Fri Mar 24, 2006 11:06 am
by Dans_03Vibe
Anybody have airbags on their vibe or matrix?
Posted: Fri Mar 24, 2006 11:10 am
by P-Fernandez
i know Damronjr has some in the front, not sur if on the back... go to search and type air bags, and click on AIR BAGS PART 1 ... hope this helps
Re: Airbags (Dans_03Vibe)
Posted: Fri Mar 24, 2006 11:27 am
by damronjr
Yep, all the way around!
Posted: Fri Mar 24, 2006 11:29 am
by Dans_03Vibe
how much were they?
by P-Fernandez
congrats... when did you get the rear ones on? so how does it ride?
Re: (Dans_03Vibe)
Posted: Fri Mar 24, 2006 11:44 am
by damronjr
I got lucky and found the full bolt-on kit on craigslist here in San Diego that had come off an XRS. It needed a little work on the back ones to fit right, but otherwise they fit and work great! B/c I got them there and used the kit only cost me $500 total and Andre and I installed them oursleves.
Re: (damronjr)
Posted: Fri Mar 24, 2006 11:49 am
by Dans_03Vibe
so any airbags fit on a vibe?
Re: (Dans_03Vibe)
Posted: Fri Mar 24, 2006 11:55 am
by damronjr
Quote, originally posted by Dans_03Vibe »so any airbags fit on a vibe?No, this was a bolt-on kit for the Vibe/Matrix. It was actually for a GT/XRS which is why I had some problems with the rear fitment, but after some modification, it fit fine. You have to find a kit that is made for this or build one yourself. The one I have is the Chassis Tech kit from airbagit.com. It's a fast kit.
Posted: Fri Mar 24, 2006 11:58 am
by Dans_03Vibe
so the base vibe is diffrent from the GTvibe?
Re: (Dans_03Vibe)
Posted: Fri Mar 24, 2006 12:01 pm
by damronjr
Quote, originally posted by Dans_03Vibe »so the base vibe is diffrent from the GTvibe?Apparently the rear suspension is as the bags wouldn't fit over the rear sway bar casing. Had to have my bro-in-law extend the posts an inch or 2 to get it to fit. Otherwise everything is the same.
