TRD coil overs available.
Posted: Tue Jan 14, 2003 2:38 am
				COILOVER SHOCKSPrice $1275Shocks: High-strength steeltubing     Twin-tube design      Cellular gas construction     32mm front piston      35mm rear piston      Lowered ride height adjustability from:     - Front,  1 1/4" to 2 3/8"      - Rear,  1 1/4" to 2 3/4"    Springs:  Linear rate at 250 lbs/in.     Stress relieved, cold-wound, shot-peened    High-tensile strength, SAE-rated    Shocks: Electronickel plated with clear-annodized adjustment perches  Includes TRD stickers    Springs: Powder-coated in red       Features/Benefits    - Twin tube design provides consistent dampning for improved control      - Ride height can be adjusted to match most road and track conditions      - Shorter shock body allows more suspension travel for improved ride quality,        driver input control and tire traction.          - Increased spring rate reduces body roll         - Spring manufacturing process ensures precision rates for predictable control        over various road conditions                  Installation procedure overview  1. Remove stock shock/spring assemblies         2. Disassemble stock shock/spring assemblies        3. Using specified stock components, assemble TRD coilover shocks      4. Pre-load coilovers at maximum ride height - 34 collar turns from bottom          of shock body threads          5. Install TRD coilover shocks          6. Adjust suspension height          7. Align vehicle                   Estimated installation time Front(1): Standard OP code 431151B,C of 1.7 hours plus .5 hours = 2.2 hours     for disassembly of 1 stock shock and assembly of 1 TRD shock.  This     includes toe-in and camber alignment.                  Front(2): OP code 431151A,B,C of 2.2 hours (see above) plus 1 hour = 3.2 hours     for disassembly of 2 stock shocks and assembly of 2 TRD shocks.  This     includes toe-in and camber alignment.                  Rear(1): Standard OP code 481251 of 1.2 hours plus .5 hours = 1.7 hours      for disassembly of 1 stock shock and assembly of 1 TRD shock.                 Rear(2): OP code 481251A of 1.7 hours (see above) plus .5 hours = 2.2 hours     for disassembly of 2 stock shocks and assembly of 2 TRD shocks.               Hardware provided  Yes, but customer will have to provide chassis lube     Instructions provided  Yes                    Other materials provided  Spanner and allen wrench       Service parts available  All shocks will be available as service parts.                          PERFORMANCE SPECIFICATIONS:          Ride height adjustment range Front: 1 1/4" to 2 3/8"          Rear: 1 1/4" to 2 3/4"          Every full adjustment collar turn results in 1/16".  16 turns = 1" change     of ride height.  When viewed from bottom of shock, counterclockwise     turns lowers and clockwise turns raises vehicle.                Skidpad vs stock*   .90 g TRD vs .83 stock       Slalom vs stock*   66 MPH TRD vs 63 MPH stock       1 mile roadcourse vs stock*  52 seconds TRD vs 54 seconds stock    PACKAGING TYPE:   non-retail                   * As tested with TRD 18" wheels on Yokohama Prada Spec 2 225x40x18 tires        Coilovers set at 2" lower than stock in front and 1.8" lower than stock in rear
