When a "hot start" issue might not be a "hot start" issue.
Posted: Fri Mar 17, 2006 8:54 am
by Cougar Vibe
Well, today was the first time I've experience the 1ZZFE hot start problem. However, after reading through several threads about it, I'm not sure what happened was the same thing.Specifics: 2005 Vibe w/5k miles. Drove the car for about 25 minutes at 40mph, then parked the car for about five hours. Went to start it and it didn't want to catch for about three seconds; turned the ignition to off, tried again and she started up no problem. Anything else I've read seems to indicate the hot start issue took place within an hour or so of being parked. Has anyone had the "hot start" issue with such long intervals?Thanks,Cougar Vibe
Re: When a "hot start" issue might not be a "hot start" issue. (Cougar Vibe)
Posted: Sat Mar 18, 2006 2:02 am
by djb383
Yes, both of my '05s have done it once in the past 6 months. Wouldn't start during several seconds of cranking, turn key off and try again, then fires right up. What's up with that.
Posted: Sat Mar 18, 2006 4:08 am
by Toasted7
The time frame on my 05 has been anywhere from 20 mins to a few hours... exact same problem.
Posted: Wed Mar 29, 2006 11:30 pm
by orbix
Same thing here- I can't find any correlation between the starting issue and how recently the Vibe's been driven.
Re: (silverawd26)
Posted: Thu Mar 30, 2006 12:12 am
by Toasted7
I wish they would figure out what the problem is and actually get it fixed for everyone out there that is having this problem... it's really annoying.
Posted: Thu Mar 30, 2006 12:27 am
FWIW, I experience a similar random glitch in my G6. Difference is, it's not a no-start issue, but rather a "the engine started but the starter keeps cranking" issue.
Re: (silverawd26)
Posted: Thu Mar 30, 2006 11:32 am
by Atomb
Quote, originally posted by silverawd26 »Not sure if it is a hot start ot cold start, but Toyota has had similar problems on some of their vehicles and there is a TSB out for certain models tro update the a part in the fuel tank. I guess the fuel is falling back into the tank. Hands are tied until GM comes out with a similar TSB.then would rotating the key to the power on position for a few seconds before rotating further to engage the starter help the situation? That would get the fuel pump going right?i don't have this problem on my 04 but i feel for you all!
Re: (silverawd26)
Posted: Thu Mar 30, 2006 12:13 pm
by ColonelPanic
Quote, originally posted by silverawd26 »That is prob because your GM has a Direct Ignition (?) or whatever its called, just tap it and it should start, I think your still used to having the Vibe. Back off a bit on the key, just tap it and it should start right up. Recent GM products do seem to have a timer of some sort set up for the starter. You really don't have to to hold the key at the start position anymore. It will keep cranking after you let off of the key, so even if you turn it for just half a second or so to start, you can let off it and it will continue to crank.
Re: (ColonelPanic)
Posted: Thu Mar 30, 2006 2:41 pm
Quote, originally posted by ColonelPanic »Recent GM products do seem to have a timer of some sort set up for the starter. You really don't have to to hold the key at the start position anymore. It will keep cranking after you let off of the key, so even if you turn it for just half a second or so to start, you can let off it and it will continue to crank. Correct.The starting sequence is all computer controlled. You just "touch" the key to the start position and the computer auto-starts the engine. There is a glitch in many 05 and 06 G6 models (and possibly Malibus as well) that causes the car to occasionally over crank and keep the starter going even after the engine has fired.On the same note, however, once the engine is running, you can't accidentally blow the starter up by turning the key to start. The computer locks out the starter once the engine is running, so turning the key to start while the engine is already running results in nothing happening.It rocks.
Posted: Fri May 05, 2006 1:56 am
by vibrtor
There is a TSB on this problem. TSB 05-06-04-074 - hot soak issue. Resolution: new PCM
Re: When a "hot start" issue might not be a "hot start" issue. (vibrtor)
Posted: Thu Jun 22, 2006 7:42 am
by csharrigan
Unfortunately the said "fix" doesn't solve monsts problems.
Posted: Thu Jun 22, 2006 10:34 am
by scherry2
Quote, originally posted by Cougar Vibe »Drove the car for about 25 minutes at 40mph, then parked the car for about five hours. Went to start it and it didn't want to catch for about three seconds; turned the ignition to off, tried again and she started up no problem. my 03 has done that since I bought it every summer when it gets hot GM's reply:cannot duplicate.....
