Pillow Ball mount optional
Posted: Thu Mar 16, 2006 11:26 pm
by GoLowDrew
What does that mean? It's mentioned on the Tein website for coilovers. If I take it to a shop (like Big O Tires) to get it installed, will they know what it means?TIA
Re: Pillow Ball mount optional (GoLowDrew)
Posted: Mon Apr 10, 2006 11:25 pm
by limE
It means that you can add the camber plates on top instaed of using the stock top mounts. I have tein ss with c one pillow ball mounts ( or camber plates ). I got the c-ones because tein doesn't sell an exact fit for our car. ( at least to the best of my knoweldge.)
Posted: Wed May 06, 2009 10:48 am
by B14CK_H4WK
where did you buy the c one pillow ball mounts from? Ive only been able to find that mount on japan sites? are their any US re-sellers?
Posted: Wed May 06, 2009 12:37 pm
by breezd
I did not install anything for the camber when I installed my Tein S-techs. And I have had no problem in the year that I have had it dropped. I recently went and had the alignment inspected and everything was fine.IMO, not necessary. But others may chime in with other experiences.
Re: Pillow Ball mount optional (limE)
Posted: Wed May 06, 2009 11:23 pm
by kevera
^ahaha,he's taking about coil-overs!Quote, originally posted by limE »It means that you can add the camber plates on top instaed of using the stock top mounts. I have tein ss with c one pillow ball mounts ( or camber plates ). I got the c-ones because tein doesn't sell an exact fit for our car. ( at least to the best of my knoweldge.)That is the way to go,c-ones FTW!!You can also look into K-sports,as they have the pillow mounts also.
Re: Pillow Ball mount optional (kevera)
Posted: Fri May 08, 2009 9:13 am
by satur9
megan racing coiloveres also come with pillowball mounts. its what i have.
Re: Pillow Ball mount optional (satur9)
Posted: Sun May 10, 2009 12:26 pm
by B14CK_H4WK
ill prob go with the c-one pillowball mounts everyone with a vibe/matrix seems to recommend them, thanks guys, i havent been on the forums too much ive been pretty busy but the vibe is still getting modded
Posted: Thu May 14, 2009 4:03 pm
by Sublimewind
Are you prepared for what it will do to your ride quality? How about noise? One will decrease the other will increase.. How much, hard to say, but the typical "top hat" for a strut isolates a LOT from the car.. (speaking from someone with coilovers and pillowball top mounts.. Wait, nobody has really said they were getting any.. lol..
Posted: Sun Aug 02, 2009 8:20 am
by B14CK_H4WK
you guys with the k sport pillow ball mounts, which car are those originally for? i was trying to find a pair and i see the corolla and celica which are prob the closest?
Re: (B14CK_H4WK)
Posted: Sun Aug 02, 2009 8:34 am
by keithvibe
Quote, originally posted by B14CK_H4WK »you guys with the k sport pillow ball mounts, which car are those originally for? i was trying to find a pair and i see the corolla and celica which are prob the closest?the cars are the same so they will bolt right upI had ksport celica coilovers on my car. they bolted right up.... but I used the celica coils because I have awd. If your going to use strickly pillowball mount the either one will do but if you were going to buy the entire coilover get the corolla ones if you have 2wd. You will have to enlarge the lower bolt holes on the front coilovers but they will fit. We are only talking 2 maybe 3mm inlargement of the holes.
Posted: Sun Aug 02, 2009 11:28 am
by B14CK_H4WK
alright as long as the bolt pattern is the same. i have the tein ss coil over kit with struts, so i wounder if ill have to enlarge the holes or not?
