check your plugs!
Posted: Mon Mar 13, 2006 2:49 am
by drunkenmaxx
for those of you that believe the 100k miles+ claim that the spark plugs are good for, stop! i have a little over 76k on mine and checked them this weekend, on a sneaking suspicion (and a little jittering at idle) sure enough, they are pretty burned up! time for new ones!
Re: check your plugs! (drunkenvibe)
Posted: Mon Mar 13, 2006 2:53 am
by damronjr
I pulled mine after my engine died and they had only been in since I put the S/C in 2500 miles ago and they were pretty bad as well. I highly suggest keeping an eye on them as well.
Posted: Mon Mar 13, 2006 5:12 am
by DavidPIL
Heya...Yeah, changed mine out at around 60k. The ceramic was a bit brown but the diode looked relatively ok. Still though, I don't think I would have wanted to go much longer. I'm sure they'd last 100k but at a drop in performance(then when you change em, the new plugs would make a bigger difference). But to maintain optimal performance though, best to change earlier. Dave
Re: check your plugs! (DavidPIL)
Posted: Mon Mar 13, 2006 11:35 pm
by drunkenmaxx
i'm changing them out this weekend, i'm anxious to see what difference makes in mpg and performance.
Posted: Sun Mar 19, 2006 11:44 pm
by drunkenmaxx
update:the verdict is in. the new plugs make a whole world of difference! my throttle response is amazingly better and my RPMs go up way faster!all 4 plugs were very ready to be changed, so 100k+ miles my (removed)!
Posted: Mon Mar 20, 2006 1:01 am
by ToolGuy
Yep I believe it! I always take those extended intervals and cut them in half, than do the maintenance, whatever it is. Specially plugs... Misfire codes can pop up as the plugs get older.
Re: check your plugs! (MiVibe-ToolGuy)
Posted: Mon Mar 20, 2006 2:44 am
by drunkenmaxx
Quote, originally posted by MiVibe-ToolGuy »Specially plugs... Misfire codes can pop up as the plugs get older. that's what i figured because i was getting a CEL when i punched it!feels good to have my oomph back.
Posted: Mon Mar 20, 2006 6:28 am
by ColonelPanic
I need to take mine out and look at them... They only have 20,000 or so on them but the car idles like crap. Jittery ain't the word for what this thing is doin' most of the time... But it runs smooth out on the highway, so I don't know if the plugs are actually the problem.So the new ones have pretty much smoothed that idle out?
Re: check your plugs! (ColonelPanic)
Posted: Mon Mar 20, 2006 6:37 am
by goodvibe
Denso iridium power plugs are all that and a bag o chips.
Re: check your plugs! (goodvibe)
Posted: Mon Mar 20, 2006 8:56 am
by Vibe_dude
Quote, originally posted by goodvibe »Denso iridium power plugs are all that and a bag o chips. I got the NGK IRIDIUMS.....hope they are just as good....i was told they are.
Re: check your plugs! (Vibe_dude)
Posted: Mon Mar 20, 2006 8:31 pm
by goodvibe
Nope http://www.densoiridium.com/spconstruction.php Their .4 tip is the smallest. Their spark is the largest and easiest to fire. Great for torque and idle. I've seen people increase the gap without issue on these. NGK make the IX plug which is their attempt to match. It has a .6 tip (standard is 1.1). That one probably works as well in a most aps. http://www.ngksparkplugs.com/p...ry=US Colonel, If you have somebody nearby with a vibe, it would take all of 15 min to swap coil packs for a test. If that doesn't help then try one of the 2 plugs mentioned. You can get for less than $50 on ebay all the time.
Posted: Mon Mar 20, 2006 9:45 pm
by drunkenmaxx
Quote, originally posted by ColonelPanic »I need to take mine out and look at them... They only have 20,000 or so on them but the car idles like crap. Jittery ain't the word for what this thing is doin' most of the time... But it runs smooth out on the highway, so I don't know if the plugs are actually the problem.So the new ones have pretty much smoothed that idle out? if after only 20k and you have iridiums, i doubt it would be the plugs. i would definitely check the boots and like goodvibe says, if you can try swapping coil packs.it didn't only smooth out the idle, the damn thing just runs ten times better. before, my car acted like it didn't want to go much over 4k RPMs, now i don't have to nail the gas to get it to.
Posted: Sat Mar 25, 2006 12:35 am
by Dezz1
Remember, we do not drive our Vibes like regular folks.
Re: check your plugs! (Dezz1)
Posted: Sat Mar 25, 2006 10:33 pm
by goodvibe
Check out Lancers link in his speed limiter thread. He found a site that has iridium Power plugs for $10.99.
Posted: Sun Mar 26, 2006 10:21 pm
by drunkenmaxx
Quote, originally posted by goodvibe »Check out Lancers link in his speed limiter thread. He found a site that has iridium Power plugs for $10.99.i got the ngk's for $7 a piece at advanced! on a side note, my car had the ngk's in it from the dealer. i thought they used the densos?
Posted: Sun Mar 26, 2006 10:37 pm
by goodvibe
Did you get the standard NGKs or the more expensive IX performance plug? It's NGKs version of the Denso Power plug. Standard tip is 1.1mm, IX plug is .6, and Power plug is .4. As the tip gets smaller, the spark gets stronger. Iridium Power plug is part of the SC package. I think the CAI help burn up the plugs as the car runs leaner Though 76k is pretty good.. I may have tried one heat range colder in one of the higher performance plugs.
Re: (goodvibe)
Posted: Sun Mar 26, 2006 11:42 pm
by drunkenmaxx
Quote, originally posted by goodvibe »Did you get the standard NGKs or the more expensive IX performance plug? i got the IX plugs. from my research on this wonderful sight, i decided that was the way to go. i wanted the densos, but they didn't have them, so that was what i got.
Re: (drunkenvibe)
Posted: Mon Mar 27, 2006 1:19 am
by goodvibe
Great plug at a great price.
Posted: Mon Mar 27, 2006 8:48 am
by Vibe_dude
I was windering has anyone had any probs removing their old plugs...i think i have still got the orginials in my car..i now have 98,000kms on her...i heard that u have to wait till the car has really cooled down to remove them after such a long time being in there....because of the aluminum heads..iam not sure if i should tackle this on my own.....what do u guys think???
Re: (Vibe_dude)
Posted: Mon Mar 27, 2006 10:14 am
by Dezz1
Dude, you should not change hot plugs anyway. The heat could offset the seating. Just change the plugs in the morning, it would be easier. You can check out my site for when I changed mine.
Re: (Vibe_dude)
Posted: Mon Mar 27, 2006 9:30 pm
by drunkenmaxx
Quote, originally posted by Vibe_dude »I was windering has anyone had any probs removing their old plugs...i think i have still got the orginials in my car..i now have 98,000kms on her...i heard that u have to wait till the car has really cooled down to remove them after such a long time being in there....because of the aluminum heads..iam not sure if i should tackle this on my own.....what do u guys think???it's not hard at all, but you definitely need the engine to be cool. i have heard that the plugs have a higher risk of breaking off if hot too, which can be an expensive oops.
Posted: Mon Mar 27, 2006 10:15 pm
by goodvibe
It's easier to strip the head when the alumunium is warm.
Re: (goodvibe)
Posted: Tue Mar 28, 2006 1:59 am
by theangrydwarf1
I replaced mine this weekend. It was time, no wonder why mine idled ruff. Bought the Densos, fifty bucks for all 4 from AutoZone. I think they helped.
Re: (drunkenvibe)
Posted: Tue Mar 28, 2006 3:45 am
by Dezz1
That expensive oops is followed by some dangs, darns, shucks.
Posted: Sun Apr 02, 2006 8:17 am
by Vibe_dude
Ya i changed the plugs.they had 98,000 kms on them..oh ya these babes were done......the car works so much better with the new NGK's i got.....denso's were to much $$ and very hard to get around here..i would recommand that u change the plugs evey 50,000 kms.
