worth it to go 17" -> 16"?
Posted: Tue Feb 28, 2006 9:31 pm
by jeffbacon
I'm not really a performance guy and would rather have a smoother ride so I'm thinking of switching from the 17" (brand new, Anyone know approx how much those 17" would be worth on eBay or locally?
Re: worth it to go 17" -> 16"? (jeffbacon)
Posted: Wed Mar 01, 2006 2:53 am
by Mavrik
Well when going back to 16" you have to keep in mind the tire difference. For example your 17" wheel diameter is bigger then the 16" tire diameter. You can't throw on 16" wheels from another Vibe as they will be to small and throw off your odometer readings, fuel MPG and possibly wheel speed sensors and ABS brake systems.best size to convert back to would be a P205/60R16. Its 0.9% slower then your 17" tires. When your speed says 60MPH your actually going 60.5MPHIf you went to the 205/55R16 size the other Vibes run, your actually going 2.3% to fast. When your speed says 60MPH, your actually going to be going 58.6MPH
Re: worth it to go 17" -> 16"? (Mavrik)
Posted: Wed Mar 01, 2006 3:12 am
by scherry2
Quote, originally posted by Mavrik » For example your 17" wheel diameter is bigger then the 16" tire diameter. your comparing 2 different thingsas long as the tire measurement from top of the tire to the bottom of the tire are the same, 16" v.s. 17" it shouldn't be a problem.Example; 17" rim with a 6" sidewall tire = 23" 16" rim with a 7" sidewall tire = 23"right?
Re: worth it to go 17" -> 16"? (scherry2)
Posted: Wed Mar 01, 2006 3:44 am
by Mavrik
when you decrease the rim size, you need to increase the sidewall size.Personally I do not think its worth it. The ride difference might go unnoticed because our 16" rims ride on 55 sidewall tires. Your 17" rides on 50 sidewalls. Since your not into the hubcap look... buying 16" alloy wheels in good condition might be hard to get unless you buy new which will be $$$.Now for me on my 17" rims I'm running a 45 side wall. Its a noticable difference but when I drove the wife's GT with her 17" stock rims on the 50 sidewall, they seemed about the same as my 16" rims felt like. Sure the rim is bigger but the sidewall on the tire is about the same.
Posted: Wed Mar 01, 2006 6:56 am
by JohnC
Quote, originally posted by jeffbacon »I'm not really a performance guy and would rather have a smoother ride so I'm thinking of switching from the 17" (brand new, Same here, I wish I would have gone to a 15" from my oem 16s. More tire for the money, bigger selection, better ride and I think they would be a little less noisey. Probably depends alot on the type of road you drive.
Posted: Wed Mar 01, 2006 9:41 am
by jeffbacon
Well I definatly notice the roads in Ottawa seem bumpier/rougher in my new Vibe then in the rental cars I used to frequent. A friend at the office thinks I will notice a difference on 16" rims (obviously with a larger sidewall) so I'm trying to guage whether it's worth the eBay hastle to try to get enough money to buy 16" wheels (rims + tires) and some extra or whether I should just be looking for a straight up trade with someone. (not sure if I'll find that but you never know until you look)
Re: (jeffbacon)
Posted: Wed Mar 01, 2006 10:23 am
by Mavrik
Well maybe you can find someone in ontario who will trade 16" alloy for 17" alloy and your set. The Vibe suspension is also a little different from the various rental cars you have been in. I can't remember how my Vibe rode on stock springs because its been so long lol If you can find some to try before sealing the deal and drive on them to see how/if they feel any different. Maybe see if someone in the area will let you try their 16" rims on the 205/55R16 size for a little drive. no damage will be done on the short term by doing that. See if it feels different. I'd offer mine but I'm not in your area.
Posted: Wed Mar 01, 2006 10:48 am
by cybermob2
if you were closer to michigan i'd trade you my steelies with 'caps for your 17s.too bad too, mine just had BRAND NEW eagle RS-A tires put on courtesy of G.M.!
Posted: Wed Mar 01, 2006 8:45 pm
by OrangeGT
I am willing to do a trade or a trade + some cash my RSA s have 22k on them but Canada is a little far to ship. What do you think it would cost?
Re: worth it to go 17" -> 16"? (OrangeGT)
Posted: Thu Mar 02, 2006 2:08 am
by Mavrik
States to province isn't to bad... the shipping costs go up if its to alaska. Otherwise its pretty affordable.
Posted: Thu Mar 02, 2006 5:16 pm
by jeffbacon
Showing how much I actually know about this stuff... I drive a friend to work yesterday and he lactually LOOKED at the wheels and apparently I already have 16's on there. doh! I'm not 100% sure where I got the idea they were 17's but no biggie, they are what I wanted. I guess it's the suspention that I'm noticiing.
Re: (jeffbacon)
Posted: Fri Mar 03, 2006 2:46 am
by Mavrik
Well you now have the option of going for 15" wheels with taller sidewalls.
Re: (Mavrik)
Posted: Fri Mar 03, 2006 6:02 pm
by ColonelPanic
Quote, originally posted by Mavrik »Well you now have the option of going for 15" wheels with taller sidewalls. That gives ya a nice, soft ride! I'm diggin' the ride I get with my 15" Blizzaks, I swear it is a lot better than what it was with the 16" all seasons, but the handling "capabilities" sure can get, well, scary at times.
