will this fit?....
Posted: Fri Feb 17, 2006 1:43 am
by remusrm
Re: will this fit?.... (remusrm)
Posted: Fri Feb 17, 2006 2:33 am
by Mase
I assume you have an 06 gt? It looks like a replica of the K&N system.Yes it will fit, but you will need to do something about the air pump. On my 06 Rolla XRS, I bought 3 feet of 3/4" rubber hose and a small filter to fit the end of the hose. I connected that to the air pump port (after removing the air pump filterbox) and routed the hose up into the engine compartment behind the headlight. You will also need a little cap to plug up the ODB port on the back of the intake. 05+ 2zz engines don't use that.
Re: will this fit?.... (Mase)
Posted: Fri Feb 17, 2006 8:23 am
by mcgusto82
fits the vibe gt. not the 1zz engines. i have the 1zz version of that intake.
Posted: Fri Feb 17, 2006 8:40 am
by Digger
Looks just like the one I instaled and it went great.
