Automatic Headlights - Daytime Running Lights System
Posted: Fri Jan 10, 2003 2:35 am
by 1234
I thought I read somewhere GM was aware of the sensitivity problem with the DRL sensor on the dash. I just got off the phone with GM customer service. The GM rep would not pass my call or concern on to someone who could answer my question, "Do you know when this problem would be rectified?" She told me she never heard of this problem....etc. It was obvious she was screening my call from upper management when I asked to speak to her supervisor. I then called my dealer. The owner, Marcell Belanger, was not available, The service manager was not available, nor was his boss!!! I seem to be having a tough time getting an answer to what I feel is simply a legitimate question and concern. What ever happened to customer service? Has GM totally lost it? Anyway, if someone could let me know if a service bulletin or recall in regard to the sensitivity of the DRL senor is in the works, I'd really appreciate it. Thanks,Dave
Re: Automatic Headlights - Daytime Running Lights System (1234)
Posted: Fri Jan 10, 2003 4:05 am
by NSimkins
I had listed a PDF document from GM describing the issue in this thread:http://forums.genvibe.com/zerothread?id=1545Here is the direct link to the document:http://www.nhtsa.dot.gov/TSBScans/sb629728.pdfI don't believe there are any official documents of any kind yet available discussing the possibility of a redesigned sensor, etc. NovaResource, I believe, stated that on his trip to Tarrytown, NY, that they were looking into a switch to turn the feature ON and OFF.
Posted: Fri Jan 17, 2003 12:19 pm
by neptune nelson
HelloI am also annoyed with the feature and the lady I talked to at Pontiac Cares # never heard of the Vibe car. I just gave up at that point and politely ended that call. The service manager at my dealer said he never heard of any complaints, but would check out my car. Well from what I hear, it is working normal. I entered a search on google and found an interesting web site that is opposed to auto lights and daytime running lights. They tell you how to disconnect one or both systems. Looks like you should be fairly electrically inclined, but it might be worth it. Check it out at http://www.lightsout.org/disable.html .Good LuckKeith
Re: Automatic Headlights - Daytime Running Lights System (neptune nelson)
Posted: Fri Jan 17, 2003 3:22 pm
by PBFlash
quote:What ever happened to customer service? Has GM totally lost it?Not just GM but Chrysler and Ford as well. They are cutting costs and staff to try and keep up with the imported cars.
