Installing different brands
Posted: Wed Feb 08, 2006 11:16 pm
by shane_c
Would it really matter if the brand of speaker I install in the front is different from those in the back? Anything I should be looking out for? I'm thinking that as long as they're both aftermarket they'll sound better than stock. Thoughts? Edit: should have mentioned it's the 4 speaker stereo that I have.
Re: Installing different brands (shane_c)
Posted: Thu Feb 09, 2006 7:05 am
by pissedoffgokart
Brand matching means nada for speakers. Generally, most aftermarket speakers will sound better than stock. There re exceptions, really cheap speakers might sound worse depending on what the stock stereo is. By really cheap I am talking about quality, not price.
Posted: Thu Feb 09, 2006 7:40 am
by burkeyro
Good Place to ask questions about Car Audio is:
http://www.tune-town.com/generally Matching speakers (Front and Rear) is not a requirement, it all is based on Sound quality, and personal preferences. The most common cause of "Blowing" a speaker is Under Powering them. Under powering a speaker causes distortion and that is what normally "Blows" a speaker. I'm not sure what Head Unit (Factory/aftermarket) you are running, and I don't know the power rating on the Stock Head Unit. But I can tell you from personal experiance to be carful if you are using a stock head unit and unamplified Aftermarket speakers. Normally Factory systems are matched. Head unit output + speaker Wattage + Speaker Ohms = optimum setup for Factory Components.
