Big Shot Question
Posted: Tue Feb 07, 2006 4:08 am
by TheShadow
I just got my universal wet kit and was wondering how big of a shot I could run safely?
Re: Big Shot Question (TheShadow)
Posted: Tue Feb 07, 2006 4:16 am
by damronjr
As far as I know 85 is the biggest you should use on stock internals.
Re: Big Shot Question (damronjr)
Posted: Tue Feb 07, 2006 4:27 am
by BlueCrush
Quote, originally posted by damronjr »As far as I know 85 is the biggest you should use on stock internals.And even at that you should think about running some sort of aftermarket piggyback like e-manage for tuning and ignition timing retard.Djblackjack18 on MO runs a 65 shot without any problems. NitrovibeGT runs a 65 shot on here as well.
Re: Big Shot Question (BlueCrush)
Posted: Tue Feb 07, 2006 5:28 am
by TheShadow
I do have forged pistons and rods. Should I upgrade injectors too?
Posted: Tue Feb 07, 2006 5:31 am
by capachkid
I see you also have cams, what did that do for you?
Posted: Tue Feb 07, 2006 5:50 am
by BlueCrush
Quote, originally posted by TheShadow »I do have forged pistons and rods. Should I upgrade injectors too?You shouldn't have to upgrade the injectors unless you want to go over 100 shot and even then you might still be ok with aftermarket fuel management,
Posted: Tue Feb 07, 2006 7:21 am
by satur9
youve got a wet kit. and pistons and rods. you should be able to do a 100 shot easy.(more with a progressive controller) get 2 stage colder plugs if you havent already.a wet shot handles the fuel. but a bigger fuel pump from
http://www.monkeywrenchracing.com might be a wise investment, along with a wideband, and emanage to pull timing a little. last 2 not really neccessary but good to have. checkout
http://www.newcelica.com f/i forum to see what those nitrous guys are running.im happy with my 50 shot.
Re: (capachkid)
Posted: Tue Feb 07, 2006 8:06 am
by TheShadow
Quote, originally posted by capachkid »I see you also have cams, what did that do for you?Well, they cam from a buddy of mine that had a gts celica. He had a 2zz crate motor that had like 250hp. He totaled the car and was parting it out so I got the cams and some other goodies. It really made a difference. With the cams, pistons and rods(.05mm bigger I think), ported and polished intake manifold, cold air intake and exhautst I dynoed 187.3hp and 170.1 ftlbs. to the wheels.
Re: (TheShadow)
Posted: Wed Feb 08, 2006 8:39 am
by mcgusto82
Quote, originally posted by TheShadow »Well, they cam from a buddy of mine that had a gts celica. He had a 2zz crate motor that had like 250hp. He totaled the car and was parting it out so I got the cams and some other goodies. It really made a difference. With the cams, pistons and rods(.05mm bigger I think), ported and polished intake manifold, cold air intake and exhautst I dynoed 187.3hp and 170.1 ftlbs. to the wheels.nice gains. how much did it cost out of pocket. and where did he get this crate engine?
Re: (mcgusto82)
Posted: Thu Feb 09, 2006 3:37 am
by TheShadow
I got the cams and internals for $250. He gave me a good deal because I helped him out with some other stuff. He got the motor from some website that builds performance toyota motors. He lives down the street from me so when I get off work and school tonight I ll see if I can get a hold of him and get the link.
