Wedding ring stuck in the vent under the seat - HELP!
Posted: Mon Feb 06, 2006 12:19 pm
by Lenny
Does anyone know how to get into the vent under the front seats? My wife dropped her wedding ring down there and it got knocked intop the vent while trying to retrieve it.Thanks,Lenny
Posted: Mon Feb 06, 2006 12:26 pm
by zionzr2
sorry to hear that!!1. Do you have a powerful shop vac? try sucking it out with a strong vac.2. fishing for it with a bent up clothes hanger.
Re: Wedding ring stuck in the vent under the seat - HELP! (Lenny)
Posted: Mon Feb 06, 2006 3:14 pm
by Baltovibe
From the pic, it appears you could fit a couple of fingers into the vent and possibly feel the ring. If it is in deeper than that, then the suggestions by zionzr2 are good to try.
Posted: Mon Feb 06, 2006 3:52 pm
by northvibe
a shop vac with a nylon covering it might work.....
Posted: Mon Feb 06, 2006 11:36 pm
by Digger
I would say the safe way to do it ( Also the hardest and the best display of your love) is to get the old tools out and remove the seat and carpet to get to the vent. If you can see it you can get a gripper on a flexible shaft at the local auto parts store or Willmar type like store. Good luck.
Re: (Digger)
Posted: Tue Feb 07, 2006 12:14 am
by GMJAP
Quote, originally posted by Digger »I would say the safe way to do it ( Also the hardest and the best display of your love) is to get the old tools out and remove the seat and carpet to get to the vent. If you can see it you can get a gripper on a flexible shaft at the local auto parts store or Willmar type like store. Good luck.Be careful if you have side airbags. They're in the seat and should be disabled before removing the seat.
Re: Wedding ring stuck in the vent under the seat - HELP! (silverawd26)
Posted: Sat Feb 11, 2006 10:55 am
by nkaltso
I droped and oil pan bolt from my pick up in that vent. I never saw it again. If I ever pull the seats and carpet up, I may find it but I wrote it off as a loss.I sure that is not a reassuring responseNick
Posted: Sat Feb 11, 2006 10:59 am
by joholste
i guess i would suggest trying to lift the front end with jacks and jack stands hoping maybe to force it back out
Re: (joholste)
Posted: Sat Feb 11, 2006 9:50 pm
by mcgusto82
remove the seats,, and pull back the carpet. it's EASY! beware if you have side bags. i think you just have to unplug your battery for about 30 minutes and then you're good. anyone care to correct me if i'm wrong??
Posted: Sun Feb 12, 2006 7:41 am
by ToolGuy
My little brother dropped a dice down the defroster vent of my car many years ago. I cut a piece of garden hose off and duct taped it to my shop vac and sucked it right out...Good luck, you can get it some how!
Posted: Sun Feb 12, 2006 9:33 am
by Vibe_dude
shop vac taped to it and the floor vents with the fan on max......might work.
Posted: Mon Mar 27, 2006 5:19 am
by Kingslayer
Call me paranoid but I think I would be more concerned as to why my wife was in the back seat of the Vibe taking her wedding ring off than how to get it back...
Posted: Mon Mar 27, 2006 8:24 am
by josholiver1
(removed)!
Posted: Mon Mar 27, 2006 10:27 am
by 1badvibe
well at least your wife knows where she lost her ring, we're still searching,
Re: (Kingslayer)
Posted: Thu Mar 30, 2006 11:34 am
by Atomb
Quote, originally posted by Kingslayer »Call me paranoid but I think I would be more concerned as to why my wife was in the back seat of the Vibe taking her wedding ring off than how to get it back...that is SO true and hillarious!!thanks for the laugh.
