Lunati Cams for 1ZZ & 2ZZ
Posted: Tue Jan 31, 2006 12:08 pm
by BlueCrush
http://performance.drivewire.c....htmlI don't know anything about them but found the info and thought I would pass it on.Edit: Just found out that Lunati is a division of Holley Performance:
http://www.holley.com/index.asp?division=Lunati
Re: Lunati Cams for 1ZZ & 2ZZ (BlueCrush)
Posted: Tue Jan 31, 2006 12:41 pm
by BlueCrush
Just received this e-mail:Lunati is a subsidiary of Holley Performance Products,Inc. The Lunati PN# 50121SBALUN listed on(
http://performance.drivewire.com/engine ... shaft.html)is for a Small Block Chevrolet - (1955-1998) & 1987 -Up LT1, LT4.
http://www.holley.com/data/Cat...n.pdfit's located on page 71Sorry for the false alarm guys!
Posted: Wed Feb 01, 2006 5:05 am
by vibedrvr04
Well it may have been a false alarm on the Lunati cams, but monkeywrenchracing.com has Crower cams in stock.
http://monkeywrenchracing.com/....htmlHere's some info direct from the page:The cams you've all been waiting for. These cams are ground from new cores for excellent quality and durability. They bolt in to the 1ZZ-FE cylinder head with no machining required.Several different grinds are available to suit your car's mods and your goals.Stage 1 is a great bolt-in solution for someone looking for a power boost for their daily driver.Stage 2 is a street/strip combo with a liveable idle and gains in the mid to high rev range. Stage 2 FI is for those with turbocharged cars.Stage 3 is a full race cam for those looking for maximum power. The Apexi Power FC is strongly recommended with stage 3 so that you can increase the rev limiter, tune fuel and VVTi, and get the most out of these cams.Stages 2 and higher require upgraded valve springs.Specs:Stage 1: 268/260 duration, .374/.347" LiftStage 2: 272/272 duration, .374/.374" LiftStage 2 FI: 262/262 duration, .397/.397 LiftStage 3: 280/280 duration, .393/.393 LiftDyno results coming soon.
Re: Lunati Cams for 1ZZ & 2ZZ (vibedrvr04)
Posted: Wed Feb 01, 2006 9:15 am
by Lancer
MMmmmmm!! Just what baby needs!
Re: Lunati Cams for 1ZZ & 2ZZ (Lancer)
Posted: Mon May 29, 2006 2:05 am
by nismo
Has anyone cammed their Vibe yet? I would like to hear a sound clip.
