Part number for 6 speaker (tweeter) sail panel?
Posted: Mon Jan 06, 2003 11:39 pm
by NY Pete
Anybody have the GM part number for the sail panel with the grill in it for the factory 6-speaker system? My car is coming with the standard 4-speaker setup, and I'd like to install some JL Audio components in the doors and retain the factory look (hide my tweeter behind the factory tweeter grille that I don't currently have). Thanks for help anybody can give!Pete
Re: Part number for 6 speaker (tweeter) sail panel? (NY Pete)
Posted: Tue Jan 07, 2003 8:29 am
by DopeVibeGT
I cant help you with the part number, but nice choice in speakers. Just stop by your dealers parts department and ask. They should only be around $15 a piece, and they may need your VIN #.
Posted: Sat Jul 26, 2003 8:57 pm
by retiredfields
I've revived this thread cause I need those part numbers also. Anyone able to look them up for me?Thanks
Re: Part number for 6 speaker (retiredfields)
Posted: Sun Mar 07, 2004 3:01 pm
by Spatula
has anyone figured this out? i too would like to put tweeters in a 4-speaker vibe, and would like to order the factory grilles for 'em. anyone know the part number(s)?
Posted: Sun Mar 07, 2004 3:22 pm
Driver Door: 88970377Passenger Door: 88970376
Re: (ragingfish)
Posted: Mon Mar 08, 2004 11:58 am
by Devlop
I gotta say I'm confused as to why people ask for the part numbers when you still need to go to the dealership to find out pricing and then order if you chose to do so. It seems as though it is just a waste to ask here.
Re: (silverawd26)
Posted: Mon Mar 08, 2004 8:53 pm
by Devlop
Ok, well that makes sense. I had forgotten about that website.
Posted: Wed Apr 07, 2004 12:16 am
by JayC
Does anyone know how much work is it to add tweeters to existing 4 speaker factory system?
Re: Part number for 6 speaker (JayC)
Posted: Wed Apr 07, 2004 12:19 am
by wicked1981
Quote, originally posted by JayC »Does anyone know how much work is it to add tweeters to existing 4 speaker factory system?To add more? or replace current ones?
Re: Part number for 6 speaker (wicked1981)
Posted: Wed Apr 07, 2004 12:24 am
by savedbyzero
I need to know how difficult it would be to ADD them to current 4 speaker setup...the 4 speaker is pretty weak on the highs....
Posted: Wed Apr 07, 2004 4:37 pm
by cdFxer
The OEM ones have a blocking cap on them, so you just wire them in parallel to the stock front speakers. Other tweets may have a true crossover to wire in or just use blocking capacitors like the OEM ones. The blocking caps are just to prevent the lower frequencies from getting to the tweeters and damaging them. The "built in" operating frequency of the tweets take care of the rest-thats why you can usually get by with just a blocking cap and not a full blown crossover.
Re: (cdFxer)
Posted: Wed Apr 07, 2004 11:50 pm
by JayC
Quote, originally posted by cdFxer »The OEM ones have a blocking cap on them, so you just wire them in parallel to the stock front speakers. Other tweets may have a true crossover to wire in or just use blocking capacitors like the OEM ones. The blocking caps are just to prevent the lower frequencies from getting to the tweeters and damaging them. The "built in" operating frequency of the tweets take care of the rest-thats why you can usually get by with just a blocking cap and not a full blown crossover. Thanks for the information. Do you know what the impedance is for the tweeter?
