Will the Toyota Matrix XR ECU work on the Vibe?
Posted: Mon Jan 02, 2006 8:29 am
by Celtic_Curse
I was wondering since I am picking up the TRD Supercharger, if I swap the entire Pontiac ECU for a Matrix ECU will my car still work? A new Toyota ECU is $300 and since the Supercharger will work with a manual and comes with it's own piggyback would this solution work?
Re: Will the Toyota Matrix XR ECU work on the Vibe? (Celtic_Curse)
Posted: Mon Jan 02, 2006 1:24 pm
by Faultline
Quote, originally posted by Celtic_Curse »I was wondering since I am picking up the TRD Supercharger, if I swap the entire Pontiac ECU for a Matrix ECU will my car still work? A new Toyota ECU is $300 and since the Supercharger will work with a manual and comes with it's own piggyback would this solution work?I believe it should. Many times I have thought about getting the celica ecu to get a higher redline and more agressive timing map.I just have not done it. What exactly are you getting? It seems like the other guys have gotten the SC and the additional injector harness without buying the TRD piggyback, then they buy their own piggy back to tune. It seems like unichip, greddy emanage or Spitsecond could supply the piggyback part. If you are already are buying the TRD piggyback unit, then your solution sounds good. If you can save money by not buying the trd piggyback, and instead buy your own, then it would seem a waste to buy the matrix ecu.Remember, at this point you wont get the warranty coverage because you are not putting it on a Matrix.
Re: Will the Toyota Matrix XR ECU work on the Vibe? (Faultline)
Posted: Tue Jan 03, 2006 2:14 am
by theangrydwarf1
If you replaced the ECU with one from a celica, what years should you look at, ie best power curve etc? This would be an interesting experiment. Thanks in advance.
Posted: Tue Jan 03, 2006 11:32 am
by Celtic_Curse
Thanks Faultline, as always full of answers. I don't want to have to go and get a Unichip to make the TRD Supercharger work with the Pontiac ECU sounds easier to just get the Matrix ECU. Its is cheaper to not buy the Piggy back ECU but since the Kits come with it why not use it.Cool idea about the Celica GT ECU though never thought of that.
Re: Will the Toyota Matrix XR ECU work on the Vibe? (theangrydwarf1)
Posted: Tue Jan 03, 2006 1:13 pm
by Faultline
Quote, originally posted by theangrydwarf1 »If you replaced the ECU with one from a celica, what years should you look at, ie best power curve etc? This would be an interesting experiment. Thanks in advance. I believe the 2003+ celica is DBW, so it would be 2000-2002. In those years there is a difference, but I already forgot. I might be getting a little confused because the GT-S's redline changes dramaticly between the years, and its the 2zz version. The celica GT (1zz) goes up to 7k I believe all 3 years, but I would research it for sure. The celica motor is rated at 140hp, where ours is 130hp for the same motor. Many people have tried to dispute its reality, but my turbo kit installer has told my that the timing curves are more agressive with the celica ecu. My piggy back unit does not change the Vibes timing curves, only the fuel. If I used the celica ecu, I would be sure to pick up some power at any boost level. My only reluctance is that I believe that I am safer underboost with the vibe ECU. I also think that I can turn the boost higher with the Vibe timing curves. I dont know for sure. ?????????My turbo installer has suggested to me to get a celica GT ecu, that I might like it.....sooooo maybe I will. I especially like the 7k redline idea.
Posted: Wed Jan 04, 2006 2:20 am
by theangrydwarf1
Quote, originally posted by Faultline »Many people have tried to dispute its reality, but my turbo kit installer has told my that the timing curves are more agressive with the celica ecu.Thanks for the info. This wouldn't suprise me. The celica is more of a sports car than the vibe or the matrix and there is no telling what GM has decided is "safe". I think I will do some research on this. hmmm.....
Posted: Tue Jan 24, 2006 5:07 am
by vibedrvr04
Now ya got me thinking too...Celica GT ECU....with CAI and Exhaust...I'm just wondering if the more aggressive power curve will make a difference on the internals of the engine...I mean it's the same engine, but god only knows what GM did to the poor thing before they put it in our vibe. Don't mind my rambling...my brain has momentary lapses into ..... what was i saying?ANYWAY...if anyone else has some info on this swap...might be a good idea. Let's hear it people!
Re: (Celtic_Curse)
Posted: Tue Jan 24, 2006 7:11 am
by damronjr
Quote, originally posted by Celtic_Curse »I don't want to have to go and get a Unichip to make the TRD Supercharger work with the Pontiac ECU sounds easier to just get the Matrix ECU. Its is cheaper to not buy the Piggy back ECU but since the Kits come with it why not use it.Woah! The TRD S/C set-up will work as-is with the Pontiac ECU. EVERYTHING in our cars are re-stickered Toyota parts! And TBHWY, most of them aren't even re-stickered, they flat out say Toyota on them! Pontiac had to special order a MAF for me just b/c it is a Toyota part! Even the GM Performance Parts S/C has TRD forged right into the ECM. It just has a GM sticker on the back with a GM part #. You can get the complete TRD S/C kit and be just fine. No other piggy-back or ECU is needed.Sorry I'm so late on this!
Re: (damronjr)
Posted: Thu Jan 26, 2006 6:46 am
by dug
yep. What jason said:I'm running a TRD SC with the TRD piggyback. Its all the same stuff.
Re: (dug)
Posted: Sat Jan 28, 2006 6:03 am
by Lancer
Hmm. I tried to make it work on mine while the Unichip was getting remapped. It didn't work for me.But you got me thinking that maybe I should try again before I need another remapping. (It sucks having the car down for a week just for something that takes < an hour to do.)
Posted: Fri Feb 03, 2006 10:32 am
by Celtic_Curse
So the TRD piggyback works on the VIbe???
Re: (Celtic_Curse)
Posted: Fri Feb 03, 2006 10:37 am
by damronjr
Quote, originally posted by Celtic_Curse »So the TRD piggyback works on the VIbe???It is the same part with a GM sticker, even the casing of the GM ECM has TRD pressed into it. If my car was here I would take a pic and show you!
Posted: Sun Feb 05, 2006 1:19 am
by Celtic_Curse
Thanks that saves me some money!!
Re: (Celtic_Curse)
Posted: Mon Mar 20, 2006 10:54 am
by Lancer
I can now confirm this too. I swapped ot the Unichip for the TRD ECU this past weekend and everything is working alright. A lot less power now though compaired to the Unichip. But it was still enough to beat a slightly modded Martix XRS pretty badly. I also did notice that my launches are stronger from the TRD set up. But mid and top end are a lot weaker. I swapped them out so I could send in the Unichip for another remapping. To make it not so rich on WOT, and to take into aount for the larger custom midpipe and high flow cat. Also to control my water/meth injection. Thanks guys for the great info!!! This saves me a huge headache of having to drive my wifes beater to work for the wek it takes for the turn-around.
