Hidden charger?
Posted: Tue Dec 20, 2005 10:13 pm
by JenniRedd
Hey everyone!! I didn't even realize our Vibes had a hidden cellphone charger till about a month ago when i read it somehwere on the internet and then a few days ago I was gonna use it but there was nothing there but an empty hole. Has anyone else discovered this problem and who should i see to get it fixed?
Re: Hidden charger? (JenniRedd)
Posted: Tue Dec 20, 2005 10:19 pm
by Baltovibe
2005 Vibes and later do not come with the accessory socket.
http://forums.genvibe.com/zerothread?id=13711 is an excellent how-to on installing one.
Posted: Tue Dec 20, 2005 10:21 pm
by damronjr
Quote, originally posted by JenniRedd »Hey everyone!! I didn't even realize our Vibes had a hidden cellphone charger till about a month ago when i read it somehwere on the internet and then a few days ago I was gonna use it but there was nothing there but an empty hole. Has anyone else discovered this problem and who should i see to get it fixed?Hidden cell-phone charger? Maybe you're referring to the cig-lighter plug that is inside center console? I think they may have quit putting those in after they changed the center cosole design in 2005? Someone knows I'm sure. Help me out here!
Re: Hidden charger? (Baltovibe)
Posted: Tue Dec 20, 2005 10:22 pm
by damronjr
Quote, originally posted by Baltovibe »2005 Vibes and later do not come with the accessory socket.
http://forums.genvibe.com/zerothread?id=13711 is an excellent how-to on installing one.There you go, beat me to it! Thanks, Balto!
Posted: Tue Dec 20, 2005 10:30 pm
by JenniRedd
Thanks bunches!! I loved the way the guy posted pics with written instructions!! I don't think I could do it myself but will print it out and maybe have my dad install it.-Jenni Redd
Re: (JenniRedd)
Posted: Tue Dec 20, 2005 11:17 pm
by Raven
If you have him wire it for you, get him to wire it to a circuit that is live even with the ignition turned off. The '03 to '04 Vibes which had the socket installed only worked with the key turned on as with the cigarette lighter.
Re: Hidden charger? (Sunny)
Posted: Tue Dec 20, 2005 11:22 pm
by Baltovibe
Joatmon has a great post on how to keep it on full time at
http://forums.genvibe.com/zerothread?id=6403
Posted: Wed Dec 21, 2005 2:22 am
by MOVibe
I have an 05 and it didn't have an outlet, only a cover, so I went back to the dealer and said that the manual indicated an outlet in the console, so they put one in for free.Give it a shot!!
Posted: Wed Dec 21, 2005 2:49 pm
by JenniRedd
I am gonna read my owner's manual first and see if i can get away with that. I have an '05 also. I will let y'all know how it goes. Thanks for the info.
Posted: Sat Dec 24, 2005 1:14 pm
by binary
What's stupid about it - is that Pontiac has left the wiring, fuse, and hole for this outlet... only deciding to not install the socket. Instead to plug the hole with a rubber stopper.Mine got shorted by a dime that fell into it... but it's on it's own fuse so it didn't affect the other 12V outlet in front of the shifter. Not the easiest fuse to change out - maybe that's the reason behind it. Too many dealer charges to replace that #@^$'ing fuse.
