Easy off DRLs
Posted: Thu Dec 15, 2005 12:16 pm
by djb383
This works great and it is easy. With engine off, pull the parking brake up ONE CLICK ONLY. Start engine and DRLs will be off, manual light switch will be functional. I jacked the rear of my Vibe up just to see if brakes were engaged - they were not. Remember, just ONE CLICK up on the parking brake but you may want check to make sure your brakes are not dragging.
Re: Easy off DRLs (djb383)
Posted: Thu Dec 15, 2005 12:50 pm
by binary
Quote, originally posted by djb383 »This works great and it is easy. With engine off, pull the parking brake up one click only. Start engine and DRLs will be off, manual light switch will be functional. I jacked the rear of my Vibe up just to see if brakes were engaged - they were not. Remember, just one click up on the parking brake but you may want check to make sure your brakes are not dragging. FYI: This doesn't work with a manual trans.I still recommend clipping the red/white wire from the drl box. It's much easier on your rear brakes.
Re: Easy off DRLs (binary)
Posted: Thu Dec 15, 2005 1:15 pm
by DavidPIL
HiIt works with the GT manual tranny. I do this occasionally(when I remember) when I just want to drive with fogs (did the neg wire mod under the steering column) or when I'm driving a long distance in the day-time.Dave
Posted: Thu Dec 15, 2005 10:29 pm
by djb383
Well, like I said, I jacked my Vibe up just to check and my brakes don't drag at one click up and you would probably find yours don't either, but check just to be safe. No cut wires and no problems. Also, I think the DRLs are a good idea and I can think of only one time each year I will need to have the DRLs off - our Christmas parade of lights in which you drive through our neighborhood after dark with only your park lights on so you can enjoy the Christmas lights. (How politically incorrect - I used the word Christmas twice, oops three times. Lets go all out - MERRY CHRISTMAS everyone and that's four times!)
Posted: Thu Dec 15, 2005 10:35 pm
by BlueCrush
I have done the same thing a few times. It is nice to be able to turn off the DRLs without having to cut anything. But the "Brake" light stays on though. That's the only annoying thing.
Re: Easy off DRLs (BlueCrush)
Posted: Thu Dec 15, 2005 10:48 pm
by djb383
Yea, kinda like your seatbelt light when you disable it, but at least the brake light does'nt constantly flash at you.
Re: Easy off DRLs
Posted: Fri Dec 16, 2005 2:13 am
by DavidPIL
Just think of it just like the green "lights on" light. Once you get used to it and know why it's on, it's not so much of an annoyance. What I've done is completely blocked out the sensor so the lights turn on all the time. Figure it's safer and much less annoying than having the full lights turn off and on all day. The brake now gives me control as to when I have the lights on or not. Actually, I usually (not always) run the Parking/Fogs when I pull the e-brake so I stll have lights. Just not the headlights A lot more versatility in the choices for what lights are on or not that way
Posted: Fri Dec 16, 2005 3:31 am
by northvibe
ah so we finally find its just 1 click..nice
Re: (northvibe)
Posted: Fri Dec 16, 2005 2:14 pm
by mcgusto82
i don't want to start a new topic, but i just don't see what's soo repulsive about the DRL's that people have to reort to cutting wires.
Posted: Fri Dec 16, 2005 10:26 pm
by northvibe
i like having them when im driving, its just when im parked and the car is running do i wan them off sometimes. i think its a great safty feature to have them on while driving.
Re: (mcgusto82)
Posted: Sat Dec 17, 2005 12:26 am
Quote, originally posted by mcgusto82 »i don't want to start a new topic, but i just do see what's soo repulsive about the DRL's that people have to reort to cutting wires.assuming a typo and you don't see why people want to disable the drlsI put a switch on mine, makes it easy to turn them off if I want to. I did this for several reasons.It was something to do. I've only done token minor mods to my car, this one was pretty easy and has been done by enough people that it is well tested. Sometimes the mod bug catches you. I'm thinking about doing the foglights on demand mod too, just to do something else. Keeps the enthusiasm for the car alive. I know it's a really minor mod, but it's still something. I like to be able to unflash other vibers. Instead of hitting them with high beams to say "hello fellow viber" I unflash them by turning off and back on the headlights. Nobody gets it, but I keep trying Probably the main reason is that sometimes I have to go through a security gate and the guards get pissed if you don't turn off the headlights when approaching. Now I can. It is almost always a good idea to not (removed) off secuity guards.Pulling the parking brake one notch probably won't hurt the rear brakes, but for me that small probablility that it would, or that I'd get used to the brake light in the dash being on that I'd drive with the brake engaged makes it not worth it. Maybe if I had an auto tranny, I probably wouldn't use the parking brake as much, but with the manual tranny I use the parking brake a lot.
