Washer Nozzel Aim
Posted: Mon Dec 12, 2005 11:48 pm
by zionzr2
How would one aim the Washer Nozzels? My passenger side could use a slight adjustment.And the rear needs to point more to the passenger side rather than straight down the back. (better to soak more of the blade)
Re: Washer Nozzel Aim (zionzr2)
Posted: Tue Dec 13, 2005 12:23 am
by ToolGuy
Bill, for the rear you may want to upgrade to the newer style nozzle. It is a two spray pattern design and works better. I know there is a thread on it since I did it and others did too. Here it is and you were the last to reply! LOL!!
http://forums.genvibe.com/zerothread?id=12385
Posted: Tue Dec 13, 2005 3:15 am
by Atomb
on my old VW i used a straight pin and my wife sat in the car and activated the nozzles whenever i said "ok, try it now".(push pin into nozzle and gently adjust as if moving a joystick)
Re: Washer Nozzel Aim (MiVibe-ToolGuy)
Posted: Tue Dec 13, 2005 5:58 am
by zionzr2
Quote, originally posted by MiVibe-ToolGuy »Bill, for the rear you may want to upgrade to the newer style nozzle. It is a two spray pattern design and works better. I know there is a thread on it since I did it and others did too. Here it is and you were the last to reply! LOL!!
http://forums.genvibe.com/zerothread?id=12385Thanks MiVibe-ToolGuyI have read those long ago, I may do that sometime, but this time of year money is tight! Wanted a temp soloution. Now to find where my wife might have a straight pin!
