wiring a 2 channel amp to a DVC sub
Posted: Mon Dec 12, 2005 2:41 pm
by dave9382
Ok I have a 2channel 500 watt rockford fosgate amp...its specs are125 W x 2 @ 4 Ohms RMS250 W x 2 @ 2 Ohms RMS500 W x 1 @ 4 Ohms Bridged RMSie it has 2 +s and 2 -s for wiring (have bridged before but that was with Single voice coil)now the sub i am looking at getting the Alpine type R only comes as a duel voice coil (with an RMS of 500 watts)it comes in either a 2ohm,2ohm DVC version or 4ohm,4ohm DVC version. 1. Which version of the sub should I get for maximum performance, power,and what is the best way to wire itI figured if there is a better way to wire it Id better figure it out now before I buy the sub so I can choose either the 2 ohm or the 4 ohm DVC version.Can I just run the 2 channel amp in parallel to the 4ohm DVC version of the sub, the 2 +s to the 2+s and the 2-s to the 2-s? Would that be the best way to give me the max power? Can you even do it this way?Thats the best way I can think of but what would be better, I obviously wanna work at 2x250 at 2ohms or bridge it 1 X 500 at 4ohms (but I dont know how you wire that into a duel voice coil)Thanks in advance
Posted: Mon Dec 12, 2005 11:11 pm
by Jahntassa
You really -really- want to run it in bridged mode. Having two seperate channels going into the same sub could lead to different power levels and you could potentially hurt the sub.
Posted: Tue Dec 13, 2005 3:11 am
by dave9382
ok how do i do that exactly, i obviously know how to do it with a SVC sub but what do i do with the extra voice coil. So I should get the 4 ohm version of the sub right?
Posted: Tue Dec 13, 2005 4:02 am
by Jahntassa
With a DVC sub you'd have to wire it in series.Have the negative from one channel of the amp (it'll be marked for bridging) to one of the coils. Run a wire from the + of that coil to the - of the other coil, then run the positive of the second coil to the + of the bridge on the amp. That'll give you a 4 Ohm load which will work with the bridging.
Re: (Jahntassa)
Posted: Tue Dec 13, 2005 4:07 am
by idontknowwhatimdoing
Quote, originally posted by Jahntassa »With a DVC sub you'd have to wire it in series.Have the negative from one channel of the amp (it'll be marked for bridging) to one of the coils. Run a wire from the + of that coil to the - of the other coil, then run the positive of the second coil to the + of the bridge on the amp. That'll give you a 4 Ohm load which will work with the bridging.Correct in every way...smart cat that Jahntassa!
Posted: Tue Dec 13, 2005 6:40 am
by dave9382
thanks guys i get it now. So that is the best way to do it and I should get the 4ohm version of the sub not the 2 ohm version right??
Posted: Tue Dec 13, 2005 7:34 am
by dave9382
wait so this diagram here shows the wiring configuration your talking about but that is witha 2ohm,2ohm duel coil sub look at option 2 at http://www.cardomain.com/shop/...&y=11So im guessing I just get the 2 ohm version of the sub???
Posted: Tue Dec 13, 2005 8:52 am
by Jahntassa
Yeah, the Dual Voice Coil 2 Ohm. That'll give you more options down the road if you decide to upgrade anything, as well.
Posted: Tue Dec 13, 2005 9:00 am
by dave9382
sweet thanks again guys and thanks jahntassa. you help my (removed) yet again, do you have like a portable brain of yours I can take around in my pocket?
