Windows stick up in cold
Posted: Thu Dec 01, 2005 11:42 pm
by MOVibe
Does anyone have problems with their windows sticking to the exterior window weatherstripping when it gets cold?When I lift the switch the window moves about 1/8", and then stops. I can see the exterior weatherstripping moving with the window. this happened on all windows, but the drivers window was the worst.This started last night, and froze again this morning.It snowed very lightly 2 days ago.I have power windows, and this is the first time it has been below freezing since I got the car.Any thoughts?
Posted: Fri Dec 02, 2005 12:16 am
by northvibe
mine did this, but we had rain, then it froze overnight so my windows and doors are semi frozen. but in my situation i think everyone that parked outside has the same issue.
Re: Windows stick up in cold (MOVibe)
Posted: Fri Dec 02, 2005 12:20 am
maybe some silicon stuff would help. [disclaimer] I've never had the problem or done anything to the various seals and weather strips on my Vibe, so I am not speaking from experience on this topic.[/disclaimer]
Posted: Fri Dec 02, 2005 12:24 am
by northvibe
yea joatmon, i wonder if theres some weatherstrip lubercation, that might help, althou it would have to not freeze up to -30 or something.
Re: (northvibe)
Posted: Fri Dec 02, 2005 3:58 am
by MOVibe
I do not think it would be a good idea to put lubracant of any kind on the weatherstripping, as it would come off on the window every time it went down, then up.Thanks for the thought though.
Re: (MOVibe)
Posted: Fri Dec 02, 2005 4:05 am
by Mavrik
Well weather strip lube can smudge on the windows when they go up and down. But be careful lowering those wondows if they are frozen, you do not want to break/bend a window regulator. my windows freeeze all the time to so I never lower them unless I have to. I'll even go inside at fast food places instead of the drive through... unless I know my window is not frozen lol.
Posted: Fri Dec 02, 2005 4:22 am
by northvibe
oh i meant for the doors freezing, not the windows.
Posted: Fri Dec 02, 2005 5:51 am
by Atomb
unless you need to open your window right away, what i do is point the dash vent closest to my window towards my window and crank the heat. That usually melts at least half the window enough to get the window down.
Re: (northvibe)
Posted: Fri Dec 02, 2005 6:00 am
by Mavrik
OH... well if your doors are frozen shut, by all means use weather strip lube, that won't streak the windows, just don't spray it on the windows.
Posted: Fri Dec 02, 2005 7:16 am
by northvibe
yea exactly mav, as for the windows i think atomb is the best way, althou it might take a bit of time to heat the whole window... OHHH what about the window deflector rain thingy, that would help keep rain from getting on the top of the window so it couldnt freeze it shut.
Re: (northvibe)
Posted: Fri Dec 02, 2005 8:33 am
by Mavrik
for my vents, the driver's far left one and the passanger far right one face the windows all the time. I then have the remaining two, one facing me and one directed down to the shifter since I'm usually always the occupant.
