New tires. and i gots a question to go with em.
Posted: Thu Nov 24, 2005 10:00 pm
by joholste
i just bought 4 new bridgestone potenza G009 i bought a 205/60-r16 which the tire calculator says is 3.2 % bigger than my old stock ones. will i need a recalibration for that?? here's the webpage they are athttp://www.bridgestonetire.com...ysize
Re: New tires. and i gots a question to go with em. (joholste)
Posted: Thu Nov 24, 2005 10:23 pm
by Raven
I don't understand why you would buy a tire with a higher profile when you are obviously looking for performance. You have lowering springs and the G009 is the 4th ranked high performance tire, I don't get it. 3% is the recommended maximum size difference.Edit: I just noticed on tirerack.com that the 205/60/16 is only $72.00 instead of $93.00 for the 205/55/16
Re: New tires. and i gots a question to go with em. (Sunny)
Posted: Thu Nov 24, 2005 10:44 pm
by mcgusto82
yeah, why you would go with higher profile tires?
Posted: Thu Nov 24, 2005 11:05 pm
by joholste
sunny got it. it was cheaper to get the 60 profiles, also a slightly larger profile helps with traction in snow. i actually got them installed for 75.00 each. so i'm still seeking the answer to my question. do i need to recalibrate my spedometer?
Posted: Fri Nov 25, 2005 12:57 am
by jasonvibe
don't bother. Most speedos read 1 to 2 mph high anyway...per the feds. So if anything you'll read about 1mph low at highway speeds. Some construction areas have stationary radar warning you when you are going too fast. Find one and check it.
Posted: Fri Nov 25, 2005 2:38 am
by djb383
Hey, you gotta do what you gotta do. Your performance will drop slightly because it is harder for the engine to turn a taller (larger diameter) tire. I went with 225/50/16 which is virtually identical in diameter to the stock 205/55/16 but is 3/4" wider.
Posted: Fri Nov 25, 2005 3:00 am
by joholste
alright so i used the little tire calculator and here's what i figured out45 mph = 36495 revolutions with 55 profile36495 rev with 60 profile = 46.49mph70 mph = 56770 rev. with 55 profile56770 rev. wit 60 profile =72.31847 mphnot too terribly big of a difference so i'm not too worried about it
Re: (joholste)
Posted: Fri Nov 25, 2005 12:33 pm
by mcgusto82
don't recalibrate. this can be your defense if you get a ticket. my wife got a wreckless driving ticket down to regular speeding because she got her car calibrated and was off a mile or so at high speed. the receipt she got didn't say exactly how off it was. the judge just looked at it and decided it wasn't a wreckless.
Posted: Fri Nov 25, 2005 10:01 pm
by scherry2
do the new tires fill the wheel well more?
Re: New tires. and i gots a question to go with em. (scherry2)
Posted: Sat Nov 26, 2005 3:48 am
by joholste
well i lowered the car last weekend and here's what the front wheel well looks like with the new tire and lowering springs.
Posted: Sun Nov 27, 2005 10:23 am
by binary
Quote, originally posted by joholste »well i lowered the car last weekend and here's what the front wheel well looks like with the new tire and lowering springs.Hey, that looks damn nice. Good work
