Cold Air Intake Concerns
Posted: Mon Nov 21, 2005 6:32 am
by lordsaber
I have the 2004 base vibe and im gettin an Injen CAI, ive been told in the past that CAI can suck up water especially in puddles, so i was wondering of i should go out and buy a water bypass valve and get a hydro shield, i already have the Heat Shield/Splash Guard, also as a side note if anyone has a CAI on there 04 base vibe, can u please tell me about how low and where the filter rests at, thanks.
Re: Cold Air Intake Concerns (lordsaber)
Posted: Mon Nov 21, 2005 6:49 am
by Raven
I had a CAI on my '04 base and drove in some wicked rain storms and through lots of huge puddles of slush and never had a problem. The filter is tucked in behind the drivers side foglight, so it is quite well protected.
Re: Cold Air Intake Concerns (Sunny)
Posted: Mon Nov 21, 2005 6:54 am
by russ257
i really only think that this is a worry if you are running a supercharger or a turbo.
Re: Cold Air Intake Concerns (russ257)
Posted: Mon Nov 21, 2005 8:23 am
by damronjr
Quote, originally posted by russ257 »i really only think that this is a worry if you are running a supercharger or a turbo. Yes and no. While that may provide a harder suction. you should still not go through any puddles high enough to submerge the filter. The splash shield should potect it well enough from rain and stuff, but if you want to be safe a hydro shield and bypass valve can't hurt. Some have also cut the CAI to make place where they can switch from CAI to short ram if needed. Hope that helps. I have on 04 base auto supercharged Vibe with Injen CAI and haven't had any problems as of yet and have driven through some good rain showers, but I'm not sure you're going to immediately notice if you are taking more water into your intake than you should be (which would be none! ) until it breaks for good. Just my $0.02!
Posted: Mon Nov 21, 2005 11:11 am
by meistees
I've had mine since March I think and was worried about water too but been through a ton of rain and no problems
Posted: Tue Nov 22, 2005 12:15 am
by DiveNut
I have the Injen CAI on my 2004 Base and have had no problems with it even in torrential down pours, car washes etc. As with any vehicle, just use discretion when approaching standing water. enjoy
Posted: Tue Nov 22, 2005 9:59 am
by francismm
i have 03 vibe and i have a CAI for 18 mths now ..ive been a lot of deep snow here in canada and rain. my vibe is like snow plow during the winter season coz its too low but i dont have problem with my intake...
Re: Cold Air Intake Concerns (francismm)
Posted: Tue Nov 22, 2005 10:18 am
by Mavrik
only time you need to be concerned is if you have water sitting above the fog lamps.
Posted: Tue Nov 22, 2005 10:21 am
by damronjr
Found a way to get around the hydrolock worries, but most will probably not want to go this route!
Re: Cold Air Intake Concerns (damronjr)
Posted: Tue Nov 22, 2005 12:37 pm
by Celtic_Curse
Quote, originally posted by damronjr » have on 04 base auto supercharged Vibe with Injen CAI and haven't had any problems as of yet Did you have to cut the CAI to make it work with the Supercharger?
Re: Cold Air Intake Concerns (Celtic_Curse)
Posted: Tue Nov 22, 2005 12:39 pm
by damronjr
Quote, originally posted by Celtic_Curse »Did you have to cut the CAI to make it work with the Supercharger?Nope, with some it has been found that they have to be cut, but I think with the Injen and the TRD CAI's, those do not have to be, just moved slightly.
Posted: Thu Nov 24, 2005 2:10 pm
by Lancer
I'm pretty sure I was the first base Vibe to put a cai on. That was like 3 years ago. Not a single problem with it yet (knock wood). I had to snip an inch on the throttle side to get it to fit better with the s/c. And I snipped an inch off the filter side to make it easier to remove and clean the filter twice a year.
Posted: Fri Nov 25, 2005 3:54 am
by northvibe
with a cai you have to cut it a inch if you install a helix power tower (throttle body spacer), blue crush did this i think, i havent gotten a intake yet but i have the power tower installed.
