				some questions i cant remember answers too
				Posted: Sun Nov 20, 2005 3:19 pm
				by northvibe
				Ok so i asked these q's in other threads but cant find them now 1. has anyone changed the color of the 115v button light to red?2. when driving and rolling the 2 back windows down does anyone else have this loud (removed) thumping noise that goes through the car and hurts your ears....i think thats it for now.... thanks!
				Re: some questions i cant remember answers too (northvibe)
				Posted: Sun Nov 20, 2005 3:41 pm
				by ragingfish
				Quote, originally posted by northvibe »Ok so i asked these q's in other threads but cant find them now 1. has anyone changed the color of the 115v button light to red?Not yet.Quote »2. when driving and rolling the 2 back windows down does anyone else have this loud (removed) thumping noise that goes through the car and hurts your ears....i think thats it for now.... thanks! This has existed in ever car I have ever owned...and the G6 too. It's normal.
				Posted: Sun Nov 20, 2005 6:48 pm
				by joholste
				the thumping is actually the aiir pressure making the noise in your car
				Posted: Sun Nov 20, 2005 7:03 pm
				by ColonelPanic
				Number 1:  Yes.TNPartsGuy has done this.  I believe you will need some tiny little bulb condom thingies and maybe a new bulb for the inverter switch?  The inverter switch lighting is incandescent, the lighter illumination is an LED. Number 2: That is one of them there normal aerodynamic things that I will never be capable of understanding.   If it has windows that can be lowered, chances are it will do this crap.   The front alone aren't that bad, but the rear down alone are, not sure why.  Lowering the front windows a bit helps a bit if the rear windows are down.  I usually lower all four to the same level for optimum and consistent aesthetics. Of course, I'm the only one who would notice something as stupid and pointless as that!   So, uh, yeah, I also do it for a possible reduction in turbulence, yeah that's it.
				Re: some questions i cant remember answers too (ColonelPanic)
				Posted: Mon Nov 21, 2005 1:01 am
				by GMJAP
				I got a red bulb "condom thingy" if you need it.  Not sure if it's the appropriate size for your bulb (tee hee), but you're welcome to it.
				Posted: Mon Nov 21, 2005 7:26 am
				by jake75
				Quote, originally posted by northvibe »Ok so i asked these q's in other threads but cant find them now 1. has anyone changed the color of the 115v button light to red?2. when driving and rolling the 2 back windows down does anyone else have this loud (removed) thumping noise that goes through the car and hurts your ears....i think thats it for now.... thanks! Well I'll be damned, those back windows DO go down!  What a concept.
				Posted: Mon Nov 21, 2005 8:51 am
				by Baltovibe
				Quote, originally posted by northvibe »Ok so i asked these q's in other threads but cant find them now 2. when driving and rolling the 2 back windows down does anyone else have this loud (removed) thumping noise that goes through the car and hurts your ears....i think thats it for now.... thanks! #2 covered in
http://forums.genvibe.com/zerothread?id=19900
				Posted: Mon Nov 21, 2005 5:13 pm
				by northvibe
				it is even really bad with all windows down. yea.....like it HURTS your ears BAD. ive never had this happen in ANY car ive had before, dangist thing. ill see if i can record something wed. when i get home and my friend has his camera.GMJAPhey that would be cool, did you use those condoms on any other bulb in the vibe?...like..if you tried it on one and found that it fit a bulb somewhere.
				Re:  (northvibe)
				Posted: Mon Nov 21, 2005 10:14 pm
				by Atomb
				Quote, originally posted by northvibe »it is even really bad with all windows down. yea.....like it HURTS your ears BAD. ive never had this happen in ANY car ive had before, dangist thing. ill see if i can record something wed. when i get home and my friend has his camera.same thing happened in my VW golf...secret is to open one front window and the OPPOSITE rear window.  The amounts aren't identical either.  I usually open driver's side all the way and the rear passanger window about 1/3 --> 1/2 of the way.Should solve the thumping....
				Re: some questions i cant remember answers too (ragingfish)
				Posted: Tue Nov 22, 2005 3:00 am
				by tnpartsguy
				Quote, originally posted by ragingfish »Not yet.I have Too!! Did it a long time ago.... It's a PITA to get the switch out to do it but I did, changed the lighter ring light out at the same time.See????
http://forums.genvibe.com/zero...78960
				Re:  (northvibe)
				Posted: Tue Nov 22, 2005 3:51 am
				by GMJAP
				Quote, originally posted by northvibe »GMJAPhey that would be cool, did you use those condoms on any other bulb in the vibe?...like..if you tried it on one and found that it fit a bulb somewhere.The bulb in the AC/Recirc switch has them, as do the button backlights in the 6CD head unit.  I would suspect other switch bulbs would be similar, but can't say for sure.  Never had the 115v switch apart.IM me with your address and I'll send it to you if you wanna try it.
				Posted: Tue Nov 22, 2005 5:07 am
				by northvibe
				hey sure that would be awesome GMJAP.did anyone finish doing the shift "dial" thing changed to red?
				Posted: Wed Apr 24, 2013 4:15 pm
				by barndp
				Hey I need some red bulb condoms, where can I get some?
