Got a ?
Posted: Fri Nov 18, 2005 5:52 pm
by NascarXprt
would any of the scion perfomance parts or wheels or struts etc. fit the vibe. this is out of courriosity because we have our annual auto and truck show this weekend and saw scion and some of their parts.oh and i will get pics from the show. if anyones intrested.
Posted: Sat Nov 19, 2005 1:12 pm
by kostby
I'm certainly no Scion expert, but I believe all the Scion engines are different from the 1zz and 2zz in the Vibe.Stock Scion wheels for the xA and xB are apparently 4-bolt, so 'NO', aftermarket wheels for xA or xB won't fit a Vibe. The Scion tC apparently has 5-bolt 100-mm bolt pattern that IS the same as the Vibe, but it appears that the offset is NOT correct. It appears to be about 48mm for the Scion, and 35-40mm on the Vibe.According to a post in the GenVibe For Sale thread, the stock Vibe alloys have the following specs: 16" x 6.5", 5 x 100mm lug spacing with +39mm offset, so the offset is different. Have you looked at one of the GenVibe 'sister' sites, http://www.scionzone.com for info? Click on the link at the bottom of any GenVibe page.
Re: (kostby)
Posted: Sat Nov 19, 2005 10:52 pm
by merckx56
*********! TC wheels fit the Vibe GT just fine. I have had no problems since I got mine installed. The stock lugs worked as well...They are 5x100 lug pattern.
Posted: Sat Nov 19, 2005 11:46 pm
by joholste
the scion engine is only 1.6L if i'm not mistaken
Posted: Sun Nov 20, 2005 7:04 am
by northvibe
at a car meet i was talking to a girl that worked at scion and we both wondered why the 1.8L 2zz. wasnt put in the scions....
Re: (northvibe)
Posted: Sun Nov 20, 2005 8:45 am
by merckx56
Xa & Xb- 1.5 liter 16v VVT-i motor = 108hp/105 torqueTc- 2.4 16v VVT-i =160hp/163 torque (Camry motor)
