car easter eggs
Posted: Fri Nov 18, 2005 7:50 am
by russ257
http://www.realtechnews.com/posts/2176this is so sweet i wanna go test drive one and then do thisthink the salesman would freak?
Re: car easter eggs (russ257)
Posted: Fri Nov 18, 2005 8:15 am
by Mavrik
climb in, turn key to ON. now steer left, right, right left, tilt steering up, down, brake, brake gas clutch e-brake. You have just enabled GODMODE for driving your Vibe. Enter the same code backwards to blow up your Vibe.
Re: car easter eggs (Mavrik)
Posted: Fri Nov 18, 2005 8:39 am
by joholste
Quote, originally posted by Mavrik »climb in, turn key to ON. now steer left, right, right left, tilt steering up, down, brake, brake gas clutch e-brake. You have just enabled GODMODE for driving your Vibe. Enter the same code backwards to blow up your Vibe.ha ha ha now what is unlimited gas???
Posted: Fri Nov 18, 2005 8:46 am
by GMJAP
Quote, originally posted by Mavrik »climb in, turn key to ON. now steer left, right, right left, tilt steering up, down, brake, brake gas clutch e-brake. You have just enabled GODMODE for driving your Vibe. Enter the same code backwards to blow up your Vibe.lol. I think CP accidently did that backwards.
Re: car easter eggs (GMJAP)
Posted: Fri Nov 18, 2005 9:10 am
by Mavrik
INF fuel code isturn key to on, now steer right, tilt wheel up, down, left, left, horn, gas, brake, gas, gas.If done properly, you won't flood your engine and you have unlocked the inf fuel cheat.
Posted: Fri Nov 18, 2005 4:22 pm
by ColonelPanic
Quote, originally posted by GMJAP »lol. I think CP accidently did that backwards.Hmm, I think that may not be far from the truth. I've been known to experiment with buttons/etc. on most electronic consumer devices to find hidden menus and the like. This is the first I've heard about Mav's cheat code, so very likely that I have tried the evil option without ever knowing it. Silly me! At any rate, that's a lot of motions to go through just to turn off your stability/traction control schtuff. One thing I was questioning the second I saw this, do they not have a button that turns the stuff off like just about every other vehicle I've seen with such a system? I see in the comments following the article that it does allegedly have one, but after reading those most hilarious comments, I don't really believe what I read there anyway. If that is the only way to disable it... At least it isn't as complicated as our remote programming procedure which makes you do the hokey pokey. That wouldn't be much fun to have to do every time.
Posted: Fri Nov 18, 2005 9:59 pm
by Jaycie685
Up, Up, Down, Down, Left, Right, Left, Right, B, A, B, A, Select, Start...Oooh! I just added 100 more HP to my Vibe!
Re: (Jaycie685)
Posted: Sat Nov 19, 2005 1:06 am
by Mavrik
Quote, originally posted by Jaycie685 »Up, Up, Down, Down, Left, Right, Left, Right, B, A, B, A, Select, Start...Oooh! I just added 100 more HP to my Vibe!only 100?left, left right, down, down, up, honk, gas, e-brake up, e-brake down, left, gas, start car, turn radio up, select heavy metal.You have now added 700whp and 700 torque.
Re: (Mavrik)
Posted: Sat Nov 19, 2005 2:11 am
by Jaycie685
Quote, originally posted by Mavrik »only 100?left, left right, down, down, up, honk, gas, e-brake up, e-brake down, left, gas, start car, turn radio up, select heavy metal.You have now added 700whp and 700 torque.Hahahah yeah that's better!
Re: (Jaycie685)
Posted: Sat Nov 19, 2005 2:52 pm
by binary
Quote, originally posted by Jaycie685 »Up, Up, Down, Down, Left, Right, Left, Right, B, A, B, A, Select, Start...Oooh! I just added 100 more HP to my Vibe!Man... I was just thinking that. Hahahaha Contra, good times.u u d d l r l r b a b a start!
Posted: Sat Nov 19, 2005 2:55 pm
by binary
Quote, originally posted by russ257 »
http://www.realtechnews.com/posts/2176this is so sweet i wanna go test drive one and then do thisthink the salesman would freak?Doing the disable routine probably would just get his attention... the way you drive after that would probably put him/her over the edge.This is why you insist on testing alone or with your spouse... no salesmen on test drives - or no sale.
