Anyone notice an engine sputter at high RPM before engine is fully warmed up
Posted: Mon Dec 30, 2002 2:08 am
by robdog
I noticed a couple of times when the engine got over 6000 rpm it seems as the rev limiter kicks in way early, nowhere near the red line. i noticed merging into traffic and had to get on it and it sputters. A friend of mine has the same problem. anyone else out there notice it???
Re: Anyone notice an engine sputter at high RPM before engine is fully warmed up (robdog)
Posted: Mon Dec 30, 2002 2:45 am
by PBFlash
This has been discussed here before. This is normal. The fuel shutoff kicks in at about 7000 rpm's until the engine oil reaches the proper temp.
Re: Anyone notice an engine sputter at high RPM before engine is fully warmed up (PBFlash)
Posted: Mon Dec 30, 2002 12:10 pm
by nkaltso
here is the info from GM if you have not already seen it.GT rev limiter under Cold conditionsTSB # 180202Item # 2 end of paragraphhttp://www.nhtsa.org/TSBScans/sb629809.pdfBase Vibe AUTO shifting at 4000 when the engine is colditem #17http://www.nhtsa.org/TSBScans/sb629850.pdfEnjoyNick
