Energy Star label
Posted: Mon Nov 14, 2005 2:33 am
by GoLowDrew
Energy Star. Some fans are energy star, some are not. Does it make any difference? Fans will reduce your AC bill anyways. Correct me if I'm wrong, Energy Star is like UL. Company have to pay $$$$ to UL to test their stuff to put that label. If the fan company don't want to pay their products to be "certified" they can't use the "Energy Star" label, but could also save energy.
Re: Energy Star label (GoLowDrew)
Posted: Mon Nov 14, 2005 2:37 am
by ToolGuy
I think it is more the energy used by the fans motor and not energy saved by reducing your cooling bills. But you are right they will contribute to less AC used in a household.
Posted: Thu Nov 17, 2005 4:55 am
by IMakeVibes
Ceiling fans that have earned the ENERGY STAR move air up to 20% more efficiently than standard ceiling fans. This can save you from $15-25 per year on utility bills, plus any additional air conditioning or heating savings you may gain when your fan is operated properly.Earning the ENERGY STARWhile ENERGY STAR qualified ceiling fans use improved motors and blade designs, you can dramatically increase your savings with ENERGY STAR qualified lighting. If your fan doesn't include lighting, be sure to purchase an ENERGY STAR qualified light kit. This lighting is efficient and long lasting, so you won't have to make frequent bulb changes.Remember, saving energy prevents pollution.To save energy while using a ceiling fan, whether with a standard or an ENERGY STAR model, (use the following tips): * Ceiling Fan Installation and Usage Tips#Reverse the fan motor in winter months.#Hang your fan so that its blades are at least one foot below the ceiling, seven feet above the floor, and two feet from the nearest wall.There is a lot of info if you go to the Energy Star site. Doesn't sound like manufacturers have to pay to have their products certified, however, their product claims are required to be backed up by lab testing.
