Defrost/defog settings...
Posted: Fri Nov 11, 2005 12:21 am
by jasonvibe
In my 2005 manual and CD it says how to use the defogger settings. "Push the A/C button. Then select a defog setting on the dial." This does not seem needed. Mine automatically turns the compressor on when either defog positions are selected. I can hear the compressor clutch click on. The windows clear pretty fast. You folks may already know this.
Re: Defrost/defog settings... (jasonvibe)
Posted: Fri Nov 11, 2005 12:41 am
by GMJAP
Quote, originally posted by jasonvibe »In my 2005 manual and CD it says how to use the defogger settings. "Push the A/C button. Then select a defog setting on the dial." This does not seem needed. Mine automatically turns the compressor on when either defog positions are selected. I can hear the compressor clutch click on. The windows clear pretty fast. You folks may already know this.It automatically kicks on the AC when either defrost setting is selected, though the AC button light does not light up.
Posted: Fri Nov 11, 2005 1:37 am
by Atomb
unless it's less than 6 or 8deg C....wait second, you got a CD?!?!
Posted: Fri Nov 11, 2005 3:14 am
by Digger
I got a CD also. what is 8deg in F.
Posted: Fri Nov 11, 2005 3:22 am
by Atomb
about 46.4 F
Posted: Fri Nov 11, 2005 4:23 am
They did the same thing in the manual for my G6. It indicates to turn on the A/C system when using the defogger...but it automatically kicks in when you switch into those modes.
Posted: Tue Jan 19, 2010 9:43 am
by Aussie Vibe
I disabled this function this function on my 03 Vibe today. Quite simple: - remove the silver radio surround, - remove the radio- reach down to the back HAVC control panel and unplug the plug with the black and yellow wires running into it.All other functions operate normally and you can still manually select A/C in the demist mode
