cant turn off heat...sort of
Posted: Wed Nov 09, 2005 8:19 pm
by 21Rouge
There is no car I have ever had that heats up as quickly as the Vibe...that's good in cold weather. However even if I select the fan to be off I still get very noticeable hot air blowing thru the vents and the only way to stop this is close the vents manually. I know my van doesnt 'act' like this ie fan off results in no or almost no heated air coming through the vents. Do others experience this?
Posted: Wed Nov 09, 2005 8:42 pm
by Jahntassa
Yup. Air comes through my vents even with the fan off.
Re: cant turn off heat...sort of (Boxgrover)
Posted: Wed Nov 09, 2005 9:09 pm
by JustinVGT
Turning the switch to off will turn the fan off, but not stop the air flow through the air inlet below the windshield. You will have to turn the temp switch to cold to stop the heat or possibly just pressing the recirculate button might work since it would stop the flow of outside air. What I do is once the cabin warms up to a comfortable temperature during the cold season, I then turn the temp dial to the middle and that keeps it perfect for me; not hot and not cold. This way I also have fresh air still coming in.
Re: cant turn off heat...sort of (JustinVGT)
Posted: Wed Nov 09, 2005 10:50 pm
by Pick
Push the cabin air recycle selector switch to ON.
Re: cant turn off heat...sort of (Pick)
Posted: Thu Nov 10, 2005 3:02 am
by Atomb
Quote, originally posted by Pick »Push the cabin air recycle selector switch to ON.i find that makes the cabin 'stuffy'...and if it's slightly damp out, you've got major window fog issues.i do what JustinVGT does...get to temp, then put it in the middle and enjoy...all while keeping the fan on "LO" and only to top vents (not windshield) while directing those vents up...that gets good circulation throughout the car.
Re: cant turn off heat...sort of (Atomb)
Posted: Thu Nov 10, 2005 2:20 pm
by mcgusto82
Quote, originally posted by Atomb »i find that makes the cabin 'stuffy'...and if it's slightly damp out, you've got major window fog issues.i do what JustinVGT does...get to temp, then put it in the middle and enjoy...all while keeping the fan on "LO" and only to top vents (not windshield) while directing those vents up...that gets good circulation throughout the car.well if the issue is flow with the fan off. then the solution would be to turn off flow. the cabin circulation switch is the flow off/on button.this is the only solution to stoping wind flow. usually i too keep the flow open with the fan either off or low and keep the temp comfortable.i really wish this car had auto temp control.
Posted: Thu Nov 10, 2005 2:22 pm
This is by design.Try redirecting the air to the floor vents instead.
