Ignition Coil Power Supply Wire ID Question?
Posted: Fri Nov 04, 2005 10:37 am
by BlueCrush
I was wondering if by chance anyone would know which of the 4 wires to each ignition coil is the power supply wire. Each coil has these wires in common: Black w/white stripeBlue w/yellow stripeWhite w/black stripeI am thinking the black w/white stripe is the power supply to each coil, but need to make sure.Any Ideas?The one listed in the instructions for the Ignition Amplifier states a different color wire than what we have.
Re: Ignition Coil Power Supply Wire ID Question? (BlueCrush)
Posted: Fri Nov 04, 2005 11:34 am
by GMJAP
You are correct - it's the black with white stripe.Schematic of the ignition coils attached for your reference.
Re: Ignition Coil Power Supply Wire ID Question? (GMJAP)
Posted: Fri Nov 04, 2005 11:41 am
by BlueCrush
Awesome! Thank you very much!
