How do you replace the rear window wiper blade? (Im not so smart)
Posted: Sat Oct 29, 2005 12:42 pm
by Fredrick_NP
Do you just buy a new refil? Im not sure how those go in or out. I have never only replaced the blade itself.(And if you do need a refill does anyone know what size it is?)
Posted: Sat Oct 29, 2005 6:08 pm
rear wiper replacement
Posted: Sat Jan 07, 2006 2:26 am
by dbuzzelli
This set of instructions about replacing the rear wiper insert doesn't seem like it works. Is it the same for a 2003 model?I tried twisting the assembly 90 degrees in the service position, and it seems its going to snap off from the arm?I can't see how this is possible. Wouldn't it just slide apart like the front wipers with a tab?
Re: How do you replace the rear window wiper blade? (Fredrick_NP)
Posted: Mon Jan 09, 2006 9:41 pm
by ToolGuy
You can also buy a standard wiper refill at the proper thickness and cut the rubber to fit reusing the metal pieces like in the procedure above.
Posted: Mon Jan 16, 2006 1:25 pm
by meistees
I had used the post from above on my 04 and got the refills fast from brandsport and the instructions posted worked great
Re: (meistees)
Posted: Tue Jan 17, 2006 3:17 am
by mspalmer
I have replaced my rear wiper blade with a silblade refill cut to size. I'm amazed at how well this works. I also replaced the front with the silblades and love them.
Posted: Mon Jan 04, 2010 11:20 pm
by jeff618
This is on another string but I thought I'd add it here too... There is an alternative to going to the dealer for a replacement rear blade on the Pontiac Vibe. It may first appear that the blade and arm are one piece but if you take a look, you'll see the wiper blade can be replaced and its actually quite simple. There may be other alternatives, but the Trico Exact Fit Rear Integral Blade at wipers123 online snaps right onto the special rear arm and looks like the factory original. Much cheaper than the dealer alternative. Comes with removal and replacement instructions too. Hope this helps.
