Rear Lock Fuse?
Posted: Mon Oct 17, 2005 11:23 pm
by Vibedad
I just discovered my rear hatch does not lock or unlock with the remote. Does it have it's own fuse? What else could / should I check?I don't want to waste the time with a trip to the Dealer.ThanksVibedad
Re: Rear Lock Fuse? (Vibedad)
Posted: Mon Oct 17, 2005 11:26 pm
by millster
Just to make sure we're on the same page, you're talking about the rear hatch door, not just the glass, correct?If so, no it's not on a seperate circuit. It should lock/unlock with the rest of the doors. If it's not doing so, it sounds as though the actuator has gone bad or a wire has some loose.
Re: Rear Lock Fuse? (millster)
Posted: Tue Oct 18, 2005 5:40 am
by Vibedad
Yes, it is the door, not the glass hatch that will not lock. I will pull the panel and check the connections. If I find nothing, it's off to the dealer, I guess!
