engine light code PO128
Posted: Sun Oct 16, 2005 11:54 pm
by MLC
Engine light keeps coming on. Had it checked 2 days ago and got Code PO128: Coolant temp below regulating temp.Light reset, no problems found... light came back on two days later.Gas cap is tight...any ideas.Thanks,MLC
Re: engine light code PO128 (MLC)
Posted: Mon Oct 17, 2005 12:15 am
by ColonelPanic
Welcome aboard. We had someone else around who had something similar, I'll see if I can dig up the thread for you.Sounds like it is running too cold... I would start with checking into the thermostat, could be stuck open, not allowing the engine to warm up to where it needs to. Wouldn't be a bad idea to get a coolant flush while you're at it. What year, engine, and mileage do you have?
Posted: Mon Oct 17, 2005 12:21 am
by ColonelPanic
Yep, here you go - same code and everything. Maybe that will help.
