2 billionth HID post
Posted: Sun Oct 16, 2005 10:30 pm
by Mr. Poopypants
Well, I ordered my HID lights, headlights and fogs. I ordered the 8000K color temp. Can't wait to get them in and post a few pics. First things first, I have to disable the DRLs.
Re: 2 billionth HID post (Mr. Poopypants)
Posted: Sun Oct 16, 2005 10:58 pm
by binary
Quote, originally posted by Mr. Poopypants »Well, I ordered my HID lights, headlights and fogs. I ordered the 8000K color temp. Can't wait to get them in and post a few pics. First things first, I have to disable the DRLs.True that - it's an easy one wire snip. Trick is contorting yourself under your dash to get at it.8000k are what I would go with too... brighter the better. I'm not in it for purple lights.
Re: 2 billionth HID post (binary)
Posted: Sun Oct 16, 2005 11:12 pm
by Mr. Poopypants
Quote, originally posted by binary »True that - it's an easy one wire snip. Trick is contorting yourself under your dash to get at it.8000k are what I would go with too... brighter the better. I'm not in it for purple lights.Yeah, after running my amp wire through the firewall, I know all about sitting updside down in the driver's seat. I like the 8000K.I didn't want to go with the pure white, I like the blueish tint. But the purple 10000K lights are really ugly and wouldn't look right on my Lava Vibe.
by ZubenElGenubi
Quote, originally posted by binary »True that - it's an easy one wire snip. Trick is contorting yourself under your dash to get at it.You could always pop the cover to the DRL sensor and disconnect it (I think this is what ragingfish did). A lot easier than doing underthedashyoga.
Re: 2 billionth HID post (ZubenElGenubi)
Posted: Sun Oct 16, 2005 11:28 pm
by Mr. Poopypants
I may just do the underdash yoga anyway, I still have to install the remote starter I bought off of Mike.
Posted: Mon Oct 17, 2005 1:44 am
by ragingfish
Quote, originally posted by binary »8000k are what I would go with too... brighter the better. I'm not in it for purple lights.Remember, 8000°K refers to color temperature, or "whiteness," not brightness. Brightness is measured in lumens or candlepower. 8000°K is a nice color. I had 6000°K heads and 7000°K fogs. Not sure why the company sent me two diff temps. I didn't think I'd notice the difference. But I did. The 6000°K still had a touch of yellow to it, while the 7000°K seemed white. 8000°K should look great. Can't wait until I get brave enough to HID the G6. Quote, originally posted by ZubenElGenubi »You could always pop the cover to the DRL sensor and disconnect it (I think this is what ragingfish did). A lot easier than doing underthedashyoga.Nope, I did the under-dash-yoga myself. Did the snip-the-yellow-wire-and-ground-one-side method. Shortly thereafter there came about another wire you could cut and not have to ground and get the same results. Figures.Quote, originally posted by Mr. Poopypants »But the purple 10000K lights are really ugly and wouldn't look right on my Lava Vibe.Anything above 8500°K or so is when you start losing light to color. 10,000°K and higher is absurd, and is more for show then function.
Re: 2 billionth HID post (ragingfish)
Posted: Mon Oct 17, 2005 10:58 pm
by binary
Quote, originally posted by ragingfish »Remember, 8000°K refers to color temperature, or "whiteness," not brightness. Brightness is measured in lumens or candlepower. True - but brightness is directly inverse of color temp, given equal power is supplied.They don't give you stronger inverters for the higher color temps, so your brightness drops the hotter your lamp is.When all is said and done a 8k bulb is going to be brighter than 9k, just like you said.
Posted: Thu Oct 20, 2005 3:36 am
by kerrykerrykerry
I think i still prefer my good ole 12k's to measly ole 8k's
Re: 2 billionth HID post (kerrykerrykerry)
Posted: Thu Oct 20, 2005 3:42 am
by damronjr
Quote, originally posted by kerrykerrykerry »I think i still prefer my good ole 12k's to measly ole 8k's Man, I still want to get those! If I could quite finding these deals that I can't pass up on, maybe someday I could save to get those!
Re: 2 billionth HID post (damronjr)
Posted: Tue Oct 25, 2005 12:37 am
by Mr. Poopypants
AAARGGGHHH. My HIDs are sitting in the entryway at the house and it's POURING rain. Not to mention the fact that I won't have a chance to install them until Friday. I wanna put them in!
Posted: Wed Oct 26, 2005 12:24 am
by Altus
Arg - feel for you.Question - what brand/make/model did you get? And do the headlights have the high/low functionality still?
Posted: Wed Oct 26, 2005 12:34 am
Quote, originally posted by ZubenElGenubi »You could always pop the cover to the DRL sensor and disconnect it (I think this is what ragingfish did). A lot easier than doing underthedashyoga.My understanding was that disconnecting the DRL sensor caused the system to always stay in DRL mode. It was a cure for having the thing switch between DRL and full headlights, which annoyed some people due to the sensitivity in the 03 models, but disconnecting the sensor is pretty much exactly what Mr. P needs to NOT do. Would cause the DRLs to be on all the time unless he specifically turned the headlights on using the switch on the turn signal lever.
Re: 2 billionth HID post (Altus)
Posted: Wed Oct 26, 2005 1:11 am
by Mr. Poopypants
I just got a foreign brand. I did get the HI/LO HIDs. I was going to get McCollugh (sp?) but the HI/LO's alone were almost $500.So I got the H4's and the 9006's 8K.
