What is the best way to make the exhaust a little quieter?
Posted: Fri Oct 14, 2005 8:41 am
by BlueCrush
I have a big fat resonator:And a Dynomax Super Turbo Muffler:I also have a custom 2.25" downpipe and exhaust piping, a high flow Magnaflow Cat and a gutted out precat. I love the tone that comes from the exhaust I would just like it to be quieter. What is the best way to make it quieter while still maintaining the tone. Should I change the resonator or the muffler or both.I read some where that: "Resonator is responsible for high rev tone and muffler is responsible for low rev tone. If you're decreasing the length of both, it'll get louder and deeper or vice versa." Is this true?
Re: What is the best way to make the exhaust a little quieter? (BlueCrush)
Posted: Fri Oct 14, 2005 6:07 pm
by mac99d
Maybe two Resonators I put the Greddy Evo 2 pipe on my car it has an resonator plus the stock one on the car. nice low tone at idle, quiet at cruising, All hell breaks lose when you are on it. I really love the way it sounds.[IMG][/IMG]
Re: What is the best way to make the exhaust a little quieter? (mac99d)
Posted: Sun Oct 16, 2005 4:28 am
by tangerine
Most exhaust companies now have silencers out. I preordered a set of proracing pipes for my Z and was told I had to order silencers with them because they will set off car alarms. silencers will make your exhaust quiet at idle/low RPM and scream at WOT.
Posted: Sun Oct 16, 2005 7:49 am
by scherry2
Quote, originally posted by BlueCrush » I love the tone that comes from the exhaust I would just like it to be quieter. What is the best way to make it quieter earplugs?
Re: What is the best way to make the exhaust a little quieter? (scherry2)
Posted: Sun Oct 16, 2005 9:03 am
by BlueCrush
Quote, originally posted by scherry2 »earplugs? Ha, Ha! I also posted this on a couple other forums and they both said to get a longer resonator mine is only 12" now. So I am going to get a 24" and install Raammaat in the trunk area. That should take care of it for now. They also said that a Turbo system would make it quieter as well. So, I guess I'll have to get one of those now, too!
Posted: Sun Oct 23, 2005 12:24 pm
by Faultline
Quote, originally posted by BlueCrush »Ha, Ha! I also posted this on a couple other forums and they both said to get a longer resonator mine is only 12" now. So I am going to get a 24" and install Raammaat in the trunk area. That should take care of it for now. They also said that a Turbo system would make it quieter as well. So, I guess I'll have to get one of those now, too! You stole my thunder! I was gunna tell ya that a turbo will make your exhaust quieter. It is just one more exuse to talk yourself into a turbocharger!
Re: What is the best way to make the exhaust a little quieter? (Faultline)
Posted: Mon Oct 24, 2005 8:57 pm
by goodvibe
MadBill inserts a potato. Increases back pressure also.
Posted: Tue Oct 25, 2005 2:04 am
by zionzr2
if none of the above have worked....then turn key to "off" position.Guaranteed not to make another peep!!
Re: (zionzr2)
Posted: Tue Nov 08, 2005 1:33 am
by BlueCrush
Well, I had the resonator swapped out today and I am very happy with the results. I went from a 12" to a 24" and it has made it quieter exactly where I wanted it. The high rmp sound was fine before but it was the low rpm that was way too loud in the cabin. Now, the interior sound and low rpm is perfect while the high rpm has remained the same. You can hear it but it is no longer deafening. It sound great! Thanks, guys for all you help!
