Fuel tank size???
Posted: Thu Oct 13, 2005 8:39 am
by jasonvibe
In the manual and brochure. I see the fuel tank is sized @ 13.2 gal. FWD and about 12 gal. AWD. But when I filled my 2005 up just after the light kicked on ....it took 12 gallons. The tank was not near empty because the gauge was not as low as it can go. I know this because I test drove it with gauge much lower before the dealer and I put gas in for the rest of the test drive. I suspect my tank is more like 13 gallons. How much fuel have you folks been able to get into yours?
Posted: Thu Oct 13, 2005 8:42 am
by ragingfish
Keep in mind some fuel is probably sitting in the filler neck, not just the tank.Not a ton, but there's still a reasonable enough amount there.You also can't be 100% sure the pumps'gauges are accurate.Also your gauge could have received a fuzzy signal for some reason. Remember, fuel gauges in cars are actually displaying the "average" of multiple readings. It does the average to give a more consistent reading of fuel, and prevents it from reacting to momentary, but sudden, shifts in fuel volume, such as a hard turn or fast start, which could trigger a false reading higher or lower then it really is. Perhaps your gauge simply was slow to update, and you really had less fuel then your gauge thought.
Re: Fuel tank size??? (jasonvibe)
Posted: Thu Oct 13, 2005 9:10 am
by GMJAP
Quote, originally posted by jasonvibe » In the manual and brochure. I see the fuel tank is sized @ 13.2 gal. FWD and about 12 gal. AWD. But when I filled my 2005 up just after the light kicked on ....it took 12 gallons. The tank was not near empty because the gauge was not as low as it can go. I know this because I test drove it with gauge much lower before the dealer and I put gas in for the rest of the test drive. I suspect my tank is more like 13 gallons. How much fuel have you folks been able to get into yours?The light "on" point can vary. I can pump in 10-11 gallons after my light goes on.As Raging said, don't trust the gauge either....
Re: (ragingfish)
Posted: Thu Oct 13, 2005 9:16 am
by jasonvibe
The pumps must be correct. The weights and measures police have to check them once a year. Stations are only allowed about a 1-2% error. The neck I suppose could hold about 2 quarts. The other day I filled it again from the gauge showing about a 1/4 tank left. I got 11.5 gal. in. Yes, I kept topping it off. I am not worried about expansion with the chilly temps lately. Gauges do change(update) some when you have done a long drive. Then shut off and restart later. I am sure I have at least 13 gal. available if needed. Just wondering if anyone else has noticed?
Posted: Thu Oct 13, 2005 10:10 am
by binary
I second Jason's statement - the pumps have to be certified correct by a state department (same department that ensures scales in supermarkets, weigh stations, etc are correct). 1-2% may be a little high - but I'm not aware of the exact number. The most I've ever put in my vibe is 11.57 gallons... and it was "pertneear" empty.I'd say the manual is accurate. You may want to check that again - run it as low as it was before, but try a dif. gas station, maybe thier pumps are off.
Posted: Thu Oct 13, 2005 10:15 am
by Mavrik
Quote, originally posted by jasonvibe » In the manual and brochure. I see the fuel tank is sized @ 13.2 gal. FWD and about 12 gal. AWD. But when I filled my 2005 up just after the light kicked on ....it took 12 gallons. The tank was not near empty because the gauge was not as low as it can go. I know this because I test drove it with gauge much lower before the dealer and I put gas in for the rest of the test drive. I suspect my tank is more like 13 gallons. How much fuel have you folks been able to get into yours?mine is the same way. I noticed this on my last fuel up. my light came on so I tanked up. Pump shut off at 12gal but I pumped to 13gal before thinking I better stop before I make a spill... fwd base it what I own and its an 04.
Re: Fuel tank size??? (Mavrik)
Posted: Thu Oct 13, 2005 11:55 am
by Digger
I just put 12.101 gal. in my 05 AWD. The low fuel light just came on as I pulled into the station. If the light is to come on with 1-2 gal in reserve as the manual said. then I should have a 13-14 gal. capacity. That is including topping of though. I have noticed the gage is not true to amount of fuel but level of fuel in the tank. I get 100 mils about out of the first quarter then another 50 till half then 50 till 3/4 then 50 till light on. So Full 1/2 and empty are spot on but in between are not.
Re: Fuel tank size??? (Digger)
Posted: Thu Oct 13, 2005 9:17 pm
by jasonvibe
that's pretty much what my says. Light comes on then I filled it. The auto off of the pump kicked in at 11+. I got 12.1 gal. or so in it. At that point I stopped. I suppose I could have put in more. So there seems to be a real 13 gallons in all of these. At least the '05. Also these gauges are not linear. Also notice the marks for 1/4 and 3/4 are spaced towards the ends of the scale.
Posted: Fri Oct 14, 2005 12:03 am
by mcgusto82
ok, i think it's safe to say that there isn't some kind of conspiracy dealing with the fuel tank size. i see no gain for pontiac or toyota if they kept the tank size a mistery. if they manual states it's 13.2 then it's 13.2. there always fuel on the neck of the fill tube. specially if you're like me nd keep toping it off.i actually thought i had read it was 13.5. i must've been seeing mushrooms.
Posted: Fri Oct 14, 2005 12:10 am
by cieglo
I've put over 12 in mine...just to see where "empty" really was I let it run down. On me GT the empty light be comin' on at about 11 gals used.
Posted: Fri Oct 14, 2005 12:12 am
by ZubenElGenubi
I'm right around 10.5-11.0 gallons when the light comes on. When filling up, I can easily put in 1.5-2.0 gallons after the first pump shutoff. The most I've ever put in the Vibe was over 14 gallons. (see scan in this related thread)http://forums.genvibe.com/zero...age=3
Posted: Fri Oct 14, 2005 12:52 am
by kostby
12.35 gallons after 349 miles of mixed driving (~28.2 mpg)
Posted: Fri Oct 14, 2005 2:53 am
by zionzr2
i have AWD my manual states 11.9 gallon tank.I have but in 14.4 gallons in one tank. I often have put in more than 13.5 gallons.I can typically get at least 2 more gallons in after the pump first clicks off as full.
Re: (zionzr2)
Posted: Tue Oct 18, 2005 10:49 am
by jasonvibe
It's agreed, the AWD's have more than the 11.9 the manual states. Much more...thanks
Re: (jasonvibe)
Posted: Tue Oct 18, 2005 11:12 am
by jake75
Have base - generally do not add fuel after automatic cutoff. Also generally do not go under 1/2 tank except sometimes on a long trip. Usually a 11 gal fill when low fuel light goes on. BTW reg 87 gas here today was $2.54. Less the5% disc via my Shell MC nets to $2.41 in round numbers.
Re: (jake75)
Posted: Tue Oct 18, 2005 12:26 pm
by Digger
You need to go north a bit. I just filled at $2.33. with card discount of 10% that makes it $2.10. I read in the manual the light does not come on at the same time mine said it will come on between 1 and 2 gal in reserve. Also, That first shut off at the pump also depends on the pump. I always try to round up to the nearest $$ when I fill up. This also makes it hard to get a good MPG rating I would say it might be +/- 1 MPG depending on how much you top off.
