Development of the 1ZZ-FE Engine
Posted: Wed Oct 12, 2005 4:43 am
by BlueCrush
I found a good .pdf file on the development of our engines. Pretty interesting read:
Attached files 1zzfe.pdf (540.8 KB)
Re: Development of the 1ZZ-FE Engine (BlueCrush)
Posted: Wed Oct 12, 2005 4:56 am
by gargoyle
Oooooo! Our engines have a "Taper Squish"!!!I have no clue what that is, but it's fun to say.
Posted: Wed Oct 12, 2005 5:15 am
by rlfreese
our engines also have the potential to put the power to the ground. these things are very well designed. too bad we have a granny tranny messing them up.
Re: (rlfreese)
Posted: Wed Oct 12, 2005 5:20 am
by damronjr
Quote, originally posted by rlfreese »our engines also have the potential to put the power to the ground. these things are very well designed. too bad we have a granny tranny messing them up.So, I'm not the only one noticing this?!?
Posted: Wed Oct 12, 2005 5:45 am
by rlfreese
nope, on top of being a Force Protection Officer i am also a Technician for the army as well. I have studied many eingines and ours is probably the best 4 cylinder design i have seen besides the suby boxer engine. and our ttanny needs a good swap. sombody needs to do research and see if we can swap the 6sp Vibe Gt/ Matrix XRS and Celica GT-S tranny or at least the celica GT 5 speed for better performance fpr us non gas friendly people.
Re: (rlfreese)
Posted: Wed Oct 12, 2005 6:23 am
by GMJAP
Quote, originally posted by rlfreese » sombody needs to do research and see if we can swap the 6sp Vibe Gt/ Matrix XRS and Celica GT-S tranny or at least the celica GT 5 speed for better performance fpr us non gas friendly people.So I assume what you're interested in on the GT/XRS tranny is the higher Final Drive Ratio?I didn't understand why it would be better at first (first and top gear ratios are the same), but I'm guessing this would be why?
Posted: Wed Oct 12, 2005 6:29 am
by rlfreese
correct, not to mention that a 6 speed would be cool to have in a base vibe or xr. but the celica gt tranny wold even be better than ours.
Re: (rlfreese)
Posted: Wed Oct 12, 2005 6:58 am
by GMJAP
Quote, originally posted by rlfreese »correct, not to mention that a 6 speed would be cool to have in a base vibe or xr. but the celica gt tranny wold even be better than ours.I'm confused. I believe the Vibe trannies are from the Celica.?EDIT: The 2005 Celica GT-S has the same gear ratios and final drive ratio as the Vibe GT / Matrix XRS
Re: (GMJAP)
Posted: Wed Oct 12, 2005 7:02 am
by MadBill
Interesting that the version of the 1ZZ in this paper uses an "exhaust header" style intake manifold, as did the Oldsmobile Quad four in its early days...
Re: (MadBill)
Posted: Wed Oct 12, 2005 7:09 am
by BlueCrush
The .pdf is dated for February, 1998. But, I believe our engines are the second or third version of the 1ZZ. So it could very well be that it the design is used from an earlier version.
Posted: Fri Oct 14, 2005 2:52 am
by rlfreese
no, our engines are from the celica, the tranny is different. the celica has more performance potential where ours is economicaly designed for gas mileage. gearing is different.
Posted: Fri Oct 14, 2005 3:03 am
by Atomb
Disregard!
Re: (rlfreese)
Posted: Fri Oct 14, 2005 3:56 am
by GMJAP
Quote, originally posted by rlfreese »no, our engines are from the celica, the tranny is different. the celica has more performance potential where ours is economicaly designed for gas mileage. gearing is different.The specs I've seen show the same 6spd gear ratios and final drvie ratio...??
Re: (GMJAP)
Posted: Fri Oct 14, 2005 11:20 pm
by goodvibe
Re: (rlfreese)
Posted: Sat Oct 15, 2005 12:41 pm
by Faultline
Quote, originally posted by rlfreese »no, our engines are from the celica, the tranny is different. the celica has more performance potential where ours is economicaly designed for gas mileage. gearing is different.I did some research once and found the the model for the celica and MRS tranny mated to the 1zz is the c56. The tranny mated to the 1zz Vibe/matrix/corrolla is the c59. The diference between the c59 and the c56 is that 3rd and 4rth gear are different. 1st 2nd and 5th are identical, but 3rd and 4th are taller in the Vibe. In the celica , 4 gear is direct drive where in our car it is an over drive gear. I may put a matrix xrs, or vibe gt 6 spd in some day. It should bolt right up. The celica gt-s 6spd trannys bolt up to the 1zz celicas.
Posted: Tue Oct 25, 2005 4:38 am
by micbarric
Just a few links about 1ZZ-FE production. Manufacturing location and statistics:
http://www.toyota.com/about/op....html1998 promotional photos from inside the West Virginia plant:
http://www.rickleephoto.com/rltoyota.htm
Re: (Faultline)
Posted: Tue Oct 25, 2005 4:46 am
by GMJAP
Quote, originally posted by Faultline »I did some research once and found the the model for the celica and MRS tranny mated to the 1zz is the c56. The tranny mated to the 1zz Vibe/matrix/corrolla is the c59. The diference between the c59 and the c56 is that 3rd and 4rth gear are different. 1st 2nd and 5th are identical, but 3rd and 4th are taller in the Vibe. In the celica , 4 gear is direct drive where in our car it is an over drive gear. I may put a matrix xrs, or vibe gt 6 spd in some day. It should bolt right up. The celica gt-s 6spd trannys bolt up to the 1zz celicas. Interesting. Thanks for posting that.
