Moons & Tunes Headunit lights?
Posted: Tue Oct 11, 2005 3:47 pm
by Herb
I'm not sure what the likelyhood of it happening is, but 5 lights have gone out on my headunit.Went to a dealer today and asked about replacement lights, but he says it's not in the system.Has anyone tackled this yet? I'm sure I can pull it out, but if I'm going to go through the effort, I'd rather have the parts on hand to replace them.
Re: Moons & Tunes Headunit lights? (Herb)
Posted: Tue Oct 11, 2005 4:41 pm
by ColonelPanic
Yikes! It may be easier to just find a replacement radio and do the ol' switcharoo! I don't know if there are really any user serviceable parts inside... Unless you're pretty handy, then go for it. Although, not a clue as to what type of bulb is in there, I doubt it is anything common.
Posted: Tue Oct 11, 2005 5:30 pm
What lights exactly?Don't take this as a question of your intelligence, but merely an attempt to eliminate the obvious. Do you realize when you swap between CD and RADIO, the lit buttons change to work with that particular mode? Example: when in CD mode, the numbers 1-6 don't light up, rather, the arrows and RDM and other CD-related parts of those buttons are lit. Switch to radio, those go out, and #1-6 light up.
Re: Moons & Tunes Headunit lights? (ragingfish)
Posted: Tue Oct 11, 2005 11:39 pm
by mcgusto82
yup, the lights do wehat raging says they do. the dealer wouldn't sell lights for the radio. they sell the radios. there's certain things the dealer won't sell unless in a complete package. plus stock radios on ebay gor for less than a hundred.
Posted: Wed Oct 12, 2005 2:38 am
by GMJAP
The button lights are little incandescent bulbs with orange-red sleeves over them. They run off 12v, but I couldn't tell you a part number or where to get similar ones.The display backlight is a grid of surface-mount LEDs behind the display.
Posted: Mon Oct 17, 2005 12:11 am
by Herb
The lights that are out are the 3/4, song list, P-Type, and this is all while have it in the Radio modeQuote, originally posted by ragingfish »What lights exactly?Don't take this as a question of your intelligence, but merely an attempt to eliminate the obvious. Do you realize when you swap between CD and RADIO, the lit buttons change to work with that particular mode? Example: when in CD mode, the numbers 1-6 don't light up, rather, the arrows and RDM and other CD-related parts of those buttons are lit. Switch to radio, those go out, and #1-6 light up.
